Oilpan clearance - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 12th, 16, 10:49 AM Thread Starter
Ty
69&76's Avatar
Oilpan clearance
I finally installed my LS1 motor in my 69. I am basically trying to set the engine and make sure everything fits properly.
I noticed that the oil pan is only a butt hair from the cross member. How much distance should there be. I am afraid that the motor will move slightly when you get on it and it could crack the oil pan. I am thinking I may have to notch out the cross member a bit to create more room.
69&76 is offline
post #2 of 5 (permalink) Old Apr 12th, 16, 01:10 PM
Simon
Re: Oilpan clearance
Before you cut, I think there are a few pans for varying clearances and adjustable mounts.
https://holley.com/products/ls_power/ls_oil_pans/
Maybe one of these will help.
slazisme is offline
post #3 of 5 (permalink) Old Apr 12th, 16, 01:57 PM
Shawn
For the cost of an oil pan and gasket to get the clearance I would highly suggest you do that instead. Holley has a perfect combination of motor mount and oil pan which will place your motor in a nice spot with great clearance all around. That way in case you decide to go a different route in the future you do not have any regret notching your crossmember
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #4 of 5 (permalink) Old Apr 12th, 16, 03:39 PM
What pan are you using?
dhutton is online now
post #5 of 5 (permalink) Old Apr 13th, 16, 05:39 AM
Corey
And what mounts?
Titan Uranus is offline
