Holley conversion oil pans, baffle kit? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 28th, 16, 01:19 PM Thread Starter
Shad
zboss86's Avatar
I'm seeing a baffle kit for the Holley conversion oil pan on their site.
Part number 302-10 & 302-11 depending on which pan you get.
So... I don't recall seeing this on the factory pan. Is oil starvation really an issue on these pans? Looks kinda gimmicky.. I assume it works off the same same principle as a baffle system in a gas tank. Just curious what you guys think, b/c it's pricey...
I read this old article.
Oil Baffle Kit for Holley LS Oil Pan
My Mistress rebuild...
zboss86 is offline
post #2 of 3 (permalink) Old Apr 28th, 16, 05:03 PM
Garth
Re: Holley conversion oil pans, baffle kit?
If your going to put the car through the twisties you'll want it. I did not use it because road course was not my intent. If you look at any aftermarket pan that's for road course it will be baffled. The pans for the swap don't have a real deep sump, keeping oil at the pick up is a problem when cornering hard.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #3 of 3 (permalink) Old Apr 28th, 16, 06:08 PM
I only used the one that came with my Holley 301-1 pan...can't say I seen an issue yet....but not into corners
68 Camaro~LSx ~all motor
