Radiators for LS - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 29th, 16, 01:16 PM Thread Starter
Shad
zboss86's Avatar
Radiators for LS
So what radiators are you guys using for your LS swaps. Anyone using a larger than typical radiator?
I believe I'm going to open up the hole in my radiator support and see how big of a radiator I can install. Between the A/C condensor, intercooler, power steering cooler, trans cooler, turbo, I'm going to be generating some heat in the engine bay.
My Mistress rebuild...
zboss86 is offline
post #2 of 9 (permalink) Old Apr 29th, 16, 01:48 PM
Chris
130fe's Avatar
Re: Radiators for LS
I am using my "old" 23 inch BE-cool one that I had before my LS swap. I found some hoses that worked with the corvette water pump and haven't had any issues in 2 years of driving it.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #3 of 9 (permalink) Old Apr 29th, 16, 02:40 PM
For my LS3 swaps I am using Entropy radiators. For my LSA swap I am using a C&R radiator with integrated oil, power steering and transmission (6L90E) coolers. I am also using their intercooler.
dhutton is offline
post #4 of 9 (permalink) Old Apr 29th, 16, 04:26 PM
3 core aluminum "stock replacement" Champion radiator here....separate trans cooler.
68 Camaro~LSx ~all motor
post #5 of 9 (permalink) Old Apr 29th, 16, 05:37 PM
Simon
slazisme is offline
post #6 of 9 (permalink) Old May 8th, 16, 09:00 AM
Wayne
On my 69/LSA I'm using a dual pass PRC radiator with an oil cooler in it. It was for a BBC so I'm using Napa hose adapters to get the hose sizes to match up.
Wayne
69 Camaro SS/RS. Fab 9. GM LSA/485 crate drive train. . C6 Z51 brakes. AirRide G bar Rushforths 18x8 19x12
Motown 454 is offline
post #7 of 9 (permalink) Old May 23rd, 16, 06:07 AM
Jason
I use a Griffin dual pass on my LSA. Just went through an Australian summer with no problems at all. I also use a modified ZL1 AFCO heat exchanger, has worked really well also.
steery is offline
post #8 of 9 (permalink) Old Jun 19th, 16, 05:19 AM
Chris
ckaram's Avatar
I went with Be Cool. This is the model I bought. Didn't go through Jegs but this is it:
http://www.jegs.com/i/Be-Cool-Radiat...rentProductId=
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #9 of 9 (permalink) Old Dec 11th, 17, 06:44 PM
Apprentice
Jeremy
Stock works well too, had good luck with a 4 core.
Jeremy Camaro is offline
