Quiet Cooling Fan(s) for LS1 - Team Camaro Tech
post #1 of 11 (permalink) Old May 14th, 16, 09:12 PM Thread Starter
Charlie
Hey guys, looking for suggestions for a quieter cooling fan for the LS1 than the two fan setup I have in there now given when the one low heat fan comes on it sounds like I am clear for take off! Just too darn loud. Suggestions appreciated.
Charlie
Edmonds, WA
1969 Camaro SS Vert LS1 T56
camaromaniac is offline
post #2 of 11 (permalink) Old May 14th, 16, 09:59 PM
Anne
Re: Quiet Cooling Fan(s) for LS1
The two-fan setup for 4th gen Camaros should be quiet - and cheap from a junkyard.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 11 (permalink) Old May 15th, 16, 11:07 AM
Jack
I have a Zirgo 16" p/n ZFU16S. Real quiet and cools my 6.0 great. I am 190-200 even in traffic. Don't remember what I paid for it.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #4 of 11 (permalink) Old May 15th, 16, 01:25 PM
Rich
I put a set of 98 - 02 Camaro fans for our LS powered 68 C10 truck, for $80 off of ebay. They are great fans move a ton of air and are dead quiet. Not sure how they fit on a 1st gen camaro.
Rich
1967 SS350, Under construction.
H20cooled is offline
post #5 of 11 (permalink) Old May 15th, 16, 03:21 PM
You could try the Entropy controller. Low speed is the two fans in series, so half voltage. Hi speed is fans in parallel, so full voltage.
Series/Parallel Cooling Fan Programmable Fan Controller - (Powered by CubeCart)
dhutton is online now
post #6 of 11 (permalink) Old May 15th, 16, 08:35 PM
Shawn
I say just get louder mufflers, problem solved
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #7 of 11 (permalink) Old May 17th, 16, 04:55 AM
dondb's Avatar
LOL.....The exact same problem i have with my LS install. I have the two electric fans at different turn on temps. But i think i can shut off the engine and still get the car moving....anyway it sounds like i should be able to get some air So I'll be watching
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
1969 Step Side LWB C10
dondb is offline
post #8 of 11 (permalink) Old May 17th, 16, 05:43 AM
The Entropy controller will significantly reduce noise. The series/parallel technique is the same one used by GM before they moved to PWM control. Likely the most cost effective solution and can use the hi/low drive signals from your ECM.
post #9 of 11 (permalink) Old May 17th, 16, 06:16 AM
Robert
I had the same problem, two small fans that worked OK but were very loud. I did the research and found that the 1992 3.8L Taurus fan moves a ton of air and is very quiet. It is a two speed fan but I only have the low speed wired and it moves a ton of air! You can buy these for under $100 new. It even has a plastic shroud, so with a few small mods I easily mounted it to an existing aluminum shroud.
Cunning69 is offline
post #10 of 11 (permalink) Old May 17th, 16, 06:40 AM
Chris
130fe's Avatar
I am using dual spal fans in my car. I remember reading somewhere that curved blade fans are quieter than straight blade ones.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #11 of 11 (permalink) Old May 22nd, 16, 10:32 PM
BonzoHansen's Avatar
1. Try rewiring them using three relays like gm did with the later 4th gens so they both come on at half speed on low and both at full voltage at high speed. http://img.photobucket.com/albums/v3...995_BOTTOM.jpg
2. Get a controller from DCC. I run one and i never hear my fans run and i dont think they have ever run at a full 12 volts.
TC Member #13
BonzoHansen is offline
