Use 302-1 oil pan for 4" stroker crank - Team Camaro Tech
post #1 of 12 (permalink) Old May 21st, 16, 06:41 PM Thread Starter
Anne
Thought I would post this because Google doesn't seem to know......
A 4" stroker crank will not clear the 302-2 Holley pan. This is the pan with the best clearance for first-gens; it will sit as low as possible in the engine bay.
But...the 302-1 will clear a stroker crank, but it requires using the tall 307 frame stands and slightly shimming the motor mounts.
Found this out in another thread courtesy of Vegas$69 and 67Rally. Thanks !
If you want to keep the engine lower with the 302-1 pan , simply notch the subframe for clearance.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 12 (permalink) Old May 22nd, 16, 06:35 AM
Todd
The Holley 302-2 pan can also be easily modified to work in a stroker application and many users have done it with great success. Raising the engine, or even running it at the height that results from using swap plates and the stock frame stands has a negative effect on the vehicle's center of gravity and your ability to acheive optimized and minimized U-joint working angles without cutting the tunnel open. The Hooker 1st-gen engine brackets and transmission crossmembers and the Holley 302-2 pan were designed specifically to negate those issues.
toddoky is offline
post #3 of 12 (permalink) Old May 22nd, 16, 05:56 PM Thread Starter
Anne
Re: Use 302-1 oil pan for 4" stroker crank
I'm not really scared of modifying the 302-2 pan ; just can't find any info on how to do it.
I know the point of contact with the crank is in the middle front of the pan and it needs to be lowered 1/4".
So the 1/4" drop in the middle should extend from the front all the way to the sump ?
Ronald Reagan
post #4 of 12 (permalink) Old May 23rd, 16, 06:35 AM
Todd
Here's a couple of photos from a member on another forum showing the basic principal of the modification...
ID:	149625   Click image for larger version
toddoky is offline
post #5 of 12 (permalink) Old May 23rd, 16, 07:43 AM
Shad
zboss86's Avatar
that's good info
My Mistress rebuild...
zboss86 is offline
post #6 of 12 (permalink) Old May 23rd, 16, 06:32 PM Thread Starter
Anne
Thanks Todd. That does look easy.
Ronald Reagan
post #7 of 12 (permalink) Old Jun 21st, 16, 06:51 PM
Tony
I ditched the Holley pan and installed a Mast Motorsports pan. It clears the 4" stroker crank in my 427ci LSX no problem, and also worked perfectly with the lower Holley/Hooker headers, engine mounts, and trans mount (T56). I will say that the Holley pan was nicer casting quality, but the Mast is acceptable.
Tony
Co-Founder,
69 Camaro SS convertible
70 Chevelle SS 454
Online Garage:
Nine Ball is offline
post #8 of 12 (permalink) Old Jun 22nd, 16, 09:08 AM
Corey
Does anyone know if the ATS road race oil pan will clear the fame without notching if the Holley motor mounts are used? I have searched and searched but I am unable to find a definitive answer. I have this pan on my current motor and the Holley mounts are in the garage as well. I am planning on using full height solid body mounts. I plan a test fitment, but would love to hear if this combo works before I go through the trouble.
I pulled the following dimensions out of the PDF manuals:
ATS Depth - 1.75"
Holley 302-1 Depth - 2.42"
Holley 302-2 Depth - 1.25"
Titan Uranus is offline
post #9 of 12 (permalink) Old Jun 22nd, 16, 06:26 PM
Corey
Well, if the Mast pan clears, then the ATS pan has a good chance as well. I was able to find the dimensions of the Mast pan on their website. The front of the Mast pan is 1.71" to 1.95".
post #10 of 12 (permalink) Old Jul 11th, 17, 07:33 AM
Apprentice
John Ryan
FWIW I bought 1 too many Holley 302-2 pans, if someone is looking for one please PM me.
Pro Stock John is offline
post #11 of 12 (permalink) Old Jul 11th, 17, 01:23 PM
DT
Donny
DT's Avatar
John, this post is a year old. You could use the classified section to sell your pan. Probably more traffic as well. Just an FYI.
DT is online now
post #12 of 12 (permalink) Old Aug 18th, 17, 10:42 AM
Ryan
I know it's an old thread, but Holley will soon be releasing the 302-3 pan which is a revision of the 302-2 pan. It has provisions for a 4" stroker crank and oil drain back ports for turbos.
Project: 1968 Camaro 5.3, T56, Z51 brakes, 12 bolt, etc.
ryeguy2006a is offline
