4L80E transmission mount - Team Camaro Tech
post #1 of 12 (permalink) Old May 22nd, 16, 05:50 AM Thread Starter
Shad
zboss86's Avatar
What transmission mount are you guys using for an 4L80E in a first gen Camaro? Holley may make one and I could be over looking it. I see several for the 6 speeds and 4L60E...
This dude is a beast and the mount is pretty far back. I thought about moving the mount location back on the subframe but I don't want it in the way of the parking brake cable.
zboss86 is offline
post #2 of 12 (permalink) Old May 22nd, 16, 05:57 AM Thread Starter
Shad
zboss86's Avatar
I found Holley's, I just over looked it the first couple times.
Part# 12627HKR
Any others out there that any likes?
zboss86 is offline
post #3 of 12 (permalink) Old May 23rd, 16, 06:01 AM
Jason
Re: 4L80E transmission mount
I've got the holley mount in my 69. Its a really nice part, very strong.
steery is offline
post #4 of 12 (permalink) Old May 23rd, 16, 07:48 AM Thread Starter
Shad
zboss86's Avatar
It does look like a nice piece... I like how they made room for the exhaust.
My Mistress rebuild...
zboss86 is offline
post #5 of 12 (permalink) Old May 26th, 16, 08:19 AM
Tony
I grabbed the Holley one as well...
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #6 of 12 (permalink) Old May 27th, 16, 09:23 PM
Anne
Guys, how much trouble did you have getting the 4L80e installed ?
Should I get a 4 lb hammer and start expanding the trans tunnel ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #7 of 12 (permalink) Old Jun 2nd, 16, 06:16 AM Thread Starter
Shad
zboss86's Avatar
It's tight with a stock tunnel. I had a buddy with a big block that said it barely fit, but he didn't have to beat it. At the time, Holley didn't make a 4L80E cross member. I'm curious what degree his engine was sitting. I've read that it's tight enough that you need full height(stock) body mounts.
The holley engine mounts put the engine a touch lower and the passenger head is about 1.5" off the firewall, so the clearance should be better. I think it can be done pretty easily.
zboss86 is offline
post #8 of 12 (permalink) Old Jun 2nd, 16, 12:44 PM
Anne
Thanks for the info Shad. I will be buying the entire Holley kit for my LS3/4L80e swap.
Ronald Reagan
post #9 of 12 (permalink) Old Jun 2nd, 16, 06:29 PM
Jack
I have the BRP Hotrods mount....but also have their engine mounts. The 4L80 is lonnnnng. Needed to use two of the existing subframe mount holes and drill two new ones.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #10 of 12 (permalink) Old Jun 12th, 16, 04:29 PM
Kip
G-Force Crossmember. Bolts right in. Super beefy. Sits tight to the body for good exhaust clearance.
kv67ssrs is offline
post #11 of 12 (permalink) Old Jun 17th, 16, 02:00 PM
Barry
can u link the one u are talking about? G- force
Outlaw434 is offline
post #12 of 12 (permalink) Old Jun 17th, 16, 08:19 PM
Kip
This is the one I had.
1968-1974 NOVA / VENTURA CROSSMEMBER - 4L80 - RCF1-4L80 - X-BODY, NOVA, VENTURA
The tranmission was behind a SBC 400. Mounted right up to the subframe holes. Dont know if it would match up if you are doing a LS... Might have to drill new holes?
kv67ssrs is offline
