Quick Question?? LS1 Swap Exhaust Question. Need Cat? - Team Camaro Tech
post #1 of 14 (permalink) Old Jun 26th, 16, 10:57 AM Thread Starter
Roger
CarAddict's Avatar
I am pulling the LS1 out of a 98 camaro for my 69 Camaro. Will the 69 need catalytic converters on it? I don't want to sell off the cats from the 98 if I will need them on the 69. They are fairly new flowmaster cats.
CarAddict is offline
post #2 of 14 (permalink) Old Jun 26th, 16, 11:00 AM
Chris
ckaram's Avatar
Re: Quick Question?? LS1 Swap Exhaust Question. Need Cat?
You shouldn't unless your state or county requires emissions testing. And on an classic this may not be required anyway?
My LS swap has headers into mufflers at the rear.
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #3 of 14 (permalink) Old Jun 26th, 16, 02:43 PM
Don't need cats, never had them in 69. Rear O2's will be turned off
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #4 of 14 (permalink) Old Jun 26th, 16, 03:07 PM
If you run all the electronics, chances are you exhaust will be cleaner than those of a carb motor'ed engine. Just guessing here. Many counties require some type of sniffer testing, not all.
TC # 349
zdld17 is offline
post #5 of 14 (permalink) Old Jun 26th, 16, 05:12 PM
Optional
68 Camaro~LSx ~all motor
post #6 of 14 (permalink) Old Jun 26th, 16, 05:45 PM Thread Starter
Roger
CarAddict's Avatar
Thanks Guys--Really appreciate it. No emission testing in MN anymore.
For exhaust, I am really not a fan of headers-I would prefer to use the stock manifolds. I don't think they will clear the PS box though. Can anyone verify? If not, is there a non header option that I can use---manifolds from a corvette, GTO, other Camaro, Aftermarket manifold that doesn't leak? I've never had a set of headers that didn't leak, which is why I prefer not to use them.
Help apppreciated
post #7 of 14 (permalink) Old Jun 27th, 16, 02:53 AM
World of difference in sealing up a LS Vs. a Gen1
Dynatech 1 7/8" x 3.5" no issues with leaks (collectors are 4-bolt)
post #8 of 14 (permalink) Old Jun 28th, 16, 05:30 AM Thread Starter
Roger
CarAddict's Avatar
One last quick question
I have the corvette accessory kit that I am putting on this motor. According to specs, the Corvette balancer is 1/16th difference than the Camaro balancer.
Do I need to change out the balancer? Have others just run the camaro balancer? I don't want to get the motor in, and have the belt thrown at higher RPM, or the belt chewed up.
Thanks again for your quick help on this. I want to keep moving forward!!
post #9 of 14 (permalink) Old Jun 28th, 16, 05:50 AM
Corey
Yes, you will have to change it out. The water pump will need to be the correct offset for the Corvette accessories also, so plan for that purchase as well.
Titan Uranus is offline
post #10 of 14 (permalink) Old Jun 28th, 16, 08:05 AM Thread Starter
Roger
CarAddict's Avatar
Thank you very much!!!
post #11 of 14 (permalink) Old Jul 28th, 16, 09:08 AM
Anne
You can get some LS3 exhaust manifolds on ebay. If you go to LS1tech.com, someone should be able to tell you if they fit.
LS1 Exhaust Manifolds Turbo Manifolds LS LS3 Camaro SS Turbo Header 30K Mile | eBay
I just bought these Holly 1-3/4" headers 3/4 length ceramic coated
https://www.holley.com/products/ls_p...arts/2473-1HKR
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #12 of 14 (permalink) Old Jul 28th, 16, 10:00 AM Thread Starter
Roger
CarAddict's Avatar
https://www.holley.com/products/ls_p...arts/2473-1HKR[/QUOTE]
I was just going to order them. How do they fit around the steering box and spark plugs. I'd like to use the OEM plug boot shields if at all possible
post #13 of 14 (permalink) Old Jul 28th, 16, 10:42 AM
Anne
I was just going to order them. How do they fit around the steering box and spark plugs. I'd like to use the OEM plug boot shields if at all possible[/QUOTE]
You will need these adapter pipes :
https://www.summitracing.com/parts/hok-42108hkr
Here are the fitment notes : https://www.holley.com/products/ls_p...arts/2473-1HKR
T56 and 4L60-70 trans fit good. Others may need bellhousing trimmed.
The steering box is not an issue
Ronald Reagan
post #14 of 14 (permalink) Old Jul 28th, 16, 01:33 PM
Use GM MLS factory exhaust gaskets and they will not leak. Do not use any of the paper gaskets. You should be happy with those headers
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
