McLeod Hydraulic clutch set up - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 6 (permalink) Old Jul 13th, 16, 05:23 PM Thread Starter
DT
Donny
DT's Avatar
Guys I ordered the McLeod firewall kit part# 1434002 for my 69. Which TO bearing should I get or do I need ?? Also I see this part# (1434002) with a QD at the end. Is the QD designation quick disconnect ?? What really is the diff between the two numbers ?? The QD is for GM to bearings I think. What about bleeding ??
DT is offline
post #2 of 6 (permalink) Old Jul 13th, 16, 06:41 PM
Vega$69's Avatar
Re: McLeod Hydraulic clutch set up
Comes with either quick connect for GM OEM TO or AN for aftermarket TO. If you're using the McLeod slip on TO get the 002 non QD
Give Billy a call at McLeod to find which throw out you need for your application.
Vega$69 is offline
post #3 of 6 (permalink) Old Jul 14th, 16, 02:32 PM Thread Starter
DT
Donny
DT's Avatar
Thanks John. I'm going to use the McLeod TO. 1364 is the part#.
DT is offline
post #4 of 6 (permalink) Old Jul 14th, 16, 02:56 PM
Vega$69's Avatar
That is the bolt on. What bell are you using.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 6 (permalink) Old Jul 14th, 16, 04:44 PM Thread Starter
DT
Donny
DT's Avatar
I will be using the 621 (LS) bellhousing. This is for a TKO 600.
DT is offline
post #6 of 6 (permalink) Old Jul 14th, 16, 05:30 PM
Vega$69's Avatar
Nice
DT likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
