Head Bolts or Studs ? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 28th, 16, 09:30 AM Thread Starter
Anne
Are studs a lot of hassle ? Guys are using the cheaper chinese head studs because ARP's are extremely expensive. And the chinese studs are proving to be reliable:
Speedmaster Chevy LS1 LS6 LS2 97 03 12 Point Head Stud Kit 4 8L 5 7L 6 0L | eBay
The LS9 (supercharged) head gasket seems to be a popular choice - about $50 each.
Here is the ARP head bolt set for Gen III engines ($170) :
Arp 134 3609 Chevy LS1 LS6 4 8 1997 03 Cylinder Head Bolt Kit 4 8 5 3L 5 7L 6 0L | eBay
What are you guys using ? Thoughts ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 3 (permalink) Old Jul 28th, 16, 10:08 AM
Re: Head Bolts or Studs ?
I would use the factory torque to yield head bolts before I would use a Chinese anything. I used ARP head studs in my 406 build and in a high compression pump gas 555 due to the studs ability to provide better clamping for my race gas motor and not to pull the threads out of the stock small block's deck. The rest of the motors I build I use head bolts as they are easier to install and with a low compression pump gas motor it is adequate for most street strip applications.
If you use studs you have to hone the block with the intended studs installed and a torque plate that meets the length of those studs (most block torque plates are just two inches thick billet aluminum). This is because the stud doesn't distort the block the way a head bolt does.
For a blown application it would depend upon the amount of boost you intend to run. More than eight pounds of boost and I would start to consider studs over head bolts.
Fasteners are a consumable in an LS-x engine. Don't go cheap as you may regret it. Depends upon whether you like replacing head gaskets and risking hydraulic shock to the motor should you blow a head gasket with out knowing it.
Big Dave
Larger Dave is offline
post #3 of 3 (permalink) Old Jul 28th, 16, 10:34 AM Thread Starter
Anne
Good point about cylinder wall distortion. My 6.0 appears to be in good shape- the cylinder walls look good.
The stock bolts are $50 so I will go with a new set of those. Don't want to distort the cylinder walls ! Thanks.
Ronald Reagan
