Need Help with LS3 Conversion Steering Hose - Team Camaro Tech
 3Likes
  • 3 Post By 69L48Z27
post #1 of 7 (permalink) Old Aug 10th, 16, 10:34 PM Thread Starter
I'm having a hard time finding a pressure hose for my LS3conversion into a 68 Camaro. I have a LS3 crate engine with the standardcorvette accessory package (non AC). Here is a link to the JEGs site withthe package I have.
http://www.jegs.com/i/Chevrolet-Performance/809/19257325/10002/-1
The kits says that the pump is GM part #15261472 which was standard for most C6 corvettes. My power steering box was an aftermarketone from Camaro Central (http://www.camarocentral.com/product_p/pow-58.htm)which was for a big block that I had in before the conversion.
I'm trying to find a pressure hose that will connect to theLS3 steering pump and be able to be modified on the other end to fit into my existingpump. The stock hoses for the corvette do not work as they are solidlines that are fitted to work with the corvette steering rack.
Anybody else already cross this path with their conversionsand have some ideas to help me out? I tried these hoses from JEGs butthey did not work.
http://www.jegs.com/i/Borgeson/153/925103/10002/-1
Thanks,
SoCal68SS is offline
post #2 of 7 (permalink) Old Aug 11th, 16, 04:47 AM
Re: Need Help with LS3 Conversion Steering Hose
You can use this adapter to let you use a hose with an AN fitting.
Earl's 961961 | Buy Earl's Corvette AN -6 To Power Steering Pump Adapter at JEGS
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 7 (permalink) Old Aug 11th, 16, 05:47 AM
Garth
I had one made at a local shop that crimped hoses. Told them what ends and used my old hose as mock up. Perfect fit and no adapters to deal with.
Find a hydraulic shop in your area.
DT, 1968RallySport and yellow69RS like this.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #4 of 7 (permalink) Old Aug 11th, 16, 12:48 PM
Chad
I made my own high pressure P/S hose using XRP products. They have a variety of fittings to work for various applications.
http://www.xrp.com/wp-content/upload...RP-CATALOG.pdf
Check out page 30-31
TCI Engineering equiped pro touring 1968 Camaro
1stgenCR is offline
post #5 of 7 (permalink) Old Aug 11th, 16, 01:29 PM
Chris
130fe's Avatar
I am running this fitting https://www.detroitspeed.com/Steerin...t-fitting.html with my C5 pump without any issues. I second the recommendation that Chad has with the XRP lines. DSE also sells a hose kit https://www.detroitspeed.com/Steerin...hose-kits.html if you want one stop shopping. I originally used the DSE low pressure line but had issues the first time I tried to remove the braided line from the PS reservoir. The outer braid separated from the inner rubber. I would build a new hose using the XRP (or there are a couple of other brands that do the same thing) for the high pressure and the factory one or the low pressure side if you are using a stock style PS box.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 7 (permalink) Old Aug 11th, 16, 02:06 PM
Vega$69's Avatar
This fitting get the connection outside the pulley and avoids potential interference at the an connection.
Vega$69 is offline
post #7 of 7 (permalink) Old Aug 11th, 16, 02:25 PM Thread Starter
Thanks for the suggestions guys. Project is finally getting close and we are down to the little details now.
