swap that keeps tranny in exact same position ? - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 10th, 16, 04:51 PM Thread Starter
Frank
I'm slowly considering swapping a carbureted LS motor in my 68 Camaro. I currently have a stock 327 mated to a 621 bellhousing and Richmond 5 speed transmission.
I worked very hard to build/modify a mounting plate for the Hurst shifter, as well as making custom shifter rods and offset stick, all that to keep from hacking/enlarging the shifter hole in the floor.
My question is, is there a swap kit (motor mounts) that will keep the transmission in the exact same position as it was with a small block ? Which headers will allow me to use the factory clutch linkage ?
Frank350 is offline
post #2 of 6 (permalink) Old Sep 10th, 16, 06:02 PM
Re: swap that keeps tranny in exact same position ?
Can't speak for the headers....but the 1.5" set backs kept me straight
these may work better ?
Dirty Dingo's will allow you to adjust to your needs
68 Camaro~LSx ~all motor
post #3 of 6 (permalink) Old Sep 10th, 16, 06:27 PM
Vega$69's Avatar
X2 on the DDs
Vega$69 is offline
post #4 of 6 (permalink) Old Sep 11th, 16, 04:51 AM
shawn
X3 on the DDs.
frog7151 is offline
post #5 of 6 (permalink) Old Sep 11th, 16, 08:38 AM
Rich
I'm in the process of installing my LS with a T56 Magnum in my 67 and I'm very close to stock position I just need to get the front down a little lower which I think I can do with a change on my motor mounts. The DD sliders work awesome and made it very easy to get the motor into the perfect stop. As for headers I have the Kooks ones they are supposed to work great with PS and the DD and the MAST oil pan I have. I have not installed them yet but I'm not to worried.
Rich
1967 SS350, Under construction.
H20cooled is offline
post #6 of 6 (permalink) Old Sep 11th, 16, 02:40 PM
Anne
I'm not aware of any LS headers that will work with the z-bar manual linkage.
Everyone has gone to hydraulic for that reason.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
