Holley engine mounting system - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 15th, 16, 06:46 PM Thread Starter
Anne
First you remove the frame stands. Then you mount the flat plates to the subframe with two flat-head countersunk bolts for each plate. The two countersunk bolts will use existing holes in the subframe - the inner bolt will be toward the front of the car.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 4 (permalink) Old Sep 15th, 16, 06:58 PM Thread Starter
Anne
Re: Holley engine mounting system
Now you have to bolt the Anchor 2292 clamshell motor mount to the mounting plate. You will have to drill one hole through the frame on each plate to do this.
The inner forward bolt hole in the plate is where you have to drill. Once you have the hole drilled, install the anchor 2292 mounts.
Ronald Reagan
post #3 of 4 (permalink) Old Sep 15th, 16, 07:00 PM Thread Starter
Anne
You bolt the engine plate to the block per the instructions.
Here is the pic :
Ronald Reagan
post #4 of 4 (permalink) Old Sep 15th, 16, 07:30 PM
Thanks, keep the pics coming...
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
