Valvetrain question - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 16th, 16, 11:10 AM Thread Starter
Anne
Valvetrain question
I have the LS3 heads installed and now need to install the rockers.
The stock rockers sit on a rocker stand that has scalloped areas for the rocker bearing to sit on :
MTM491-003 - Mast Medium Bore Rocker Stand for GM OEM LS3/L92 Rockers
I have a set of 1.8 Crane gold rockers. I believe the rocker stand gets eliminated and a stud gets installed where the stand was. Then the crane rockers pivits on the stud just like a SBC or BBC rockers would.
Does that sound correct ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 5 (permalink) Old Sep 16th, 16, 11:56 AM Thread Starter
Anne
Re: Valvetrain question
I found the instructions at Crane's website.
Duh, don't know why i didn't think of it before.
http://www.cranecams.com/uploads/instructions/561e_.pdf
Ronald Reagan
post #3 of 5 (permalink) Old Sep 16th, 16, 06:47 PM Thread Starter
Anne
Hey guys,
The stock LS3 rocker arm setup is hard to beat. I have inherited a set of crane gold 1.8 ratio shaft-mounted rockers that are very expensive.
But I'm thinking they might perform worse in my setup.
Comp Cams sells a factory setup that has improved bearings :
PACE Performance - GMP-346-1372 LS3 Rocker Arm Set with Installed HD Trunnions with Bolts
I think the crane rockers will add weight to the valvetrain and cause valve float unless I install stiffer springs.
Any ideas here? I think I can sell the crane rockers for what the comp cam upgraded stockers cost.
Which way would you proceed ?
Ronald Reagan
post #4 of 5 (permalink) Old Sep 16th, 16, 07:07 PM Thread Starter
Anne
Just came across this and it looks like an awesome rocker setup :
LS bushing trunnion kits - Straub Technologies
Maybe we can get Chris Straub to comment on this ? He usually hangs out in the engine section of this website.
Ronald Reagan
post #5 of 5 (permalink) Old Sep 17th, 16, 04:59 AM
I have looked at both the CS bushing kit and the upgraded bearing kits.
With the cam I'm running as well as the spring pressure....it is a concern in the back of my head.
As for the Crane rockers, no ideas, but should flip easy.
68 Camaro~LSx ~all motor
