What to do about steam vents - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 15th, 16, 06:22 PM Thread Starter
Anne
My block is the 2000 cast iron LQ4. It had hard lines for the steam vents.
I came across these steam vents from GM Performance. Can I run one on each corner and eliminate the hard lines ?
https://www.amazon.com/gp/product/B0...W36GX3HP8JDQ1S
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 5 (permalink) Old Oct 15th, 16, 06:51 PM
Vega$69's Avatar
Re: What to do about steam vents
That part is used to eliminate the steam ports on the rear of the head on early LS engines as it was determined you don't need them on all for corners.
I use the GM hard line with the built in T and run the steam vent to a port on the radiator.
You can also drill and tap the suction side of the water pump or use the Jaguar style fitting that goes in the radiator hose.
Many aftermarket guys sell braided steam vent kits. They tend end up a little bulky with the fittings and cost a bunch.
I like the factory hard line front crossover vent.
LS6 Steam Vent Crossover Pipe and Plugs - 12602544, 12602540 12602544-KIT
Vega$69 is offline
post #3 of 5 (permalink) Old Oct 15th, 16, 07:51 PM Thread Starter
Anne
Excellent. I'll buy that kit and connect to the water pump.
I like the idea of drilling and tapping the water pump and putting a barbed fitting in there. Sounds easy.
Ronald Reagan
post #4 of 5 (permalink) Old Nov 8th, 16, 08:34 AM
Robert
I ran mine down to the heater core in/out since I plugged them anyways. Trying something different.
Vegas69RS is offline
post #5 of 5 (permalink) Old Dec 11th, 17, 06:36 PM
Apprentice
Jeremy
I have used the heater core hoses as well. I run a hose from the throttle body side exit port to a "T" fitting on one of the lines going to the heater core. Works mint. You can by pass the throttle body completely to add a couple HP.
Jeremy Camaro is offline
