LS friend aftermarket subframes - Team Camaro Tech
 2Likes
  • 2 Post By dhutton
post #1 of 9 (permalink) Old Nov 16th, 16, 09:23 AM Thread Starter
Rico
Are there any aftermarket subframes that already resolve clearance issues with a/c compressor, alternator, p/s and the frame. im in the market for suspension and i have a GTO LS1.
Ricoshay is offline
post #2 of 9 (permalink) Old Nov 16th, 16, 11:09 AM
Re: LS friend aftermarket subframes
Art Morrison works with stock 4th gen F body accessories and oil pan. If you want to use a Sanden compressor you can use the Allan Grove low mount bracket and a rear exit compressor.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 9 (permalink) Old Nov 16th, 16, 01:30 PM Thread Starter
Rico
So it will clear everything and i just have to use the sanden for aftermarket a/c compatibility?
Any more recommendations? Its looks like i'll spend over $1000 just in brackets, compressor, pump,alt if i use stock subframe.
Ricoshay is offline
post #4 of 9 (permalink) Old Nov 16th, 16, 01:48 PM
Rich
There are lots of aftermarket subframes for the 1st gen with an LS motor, Speedtech, Detroitspeed, I would just pick one of them and call. I had great success with Speedtech when I called them they are very helpful.
Rich
1967 SS350, Under construction.
H20cooled is offline
post #5 of 9 (permalink) Old Nov 16th, 16, 03:03 PM
Vega$69's Avatar
You'll have $1000 or more in any front drive set-up you use with the stock or aftermarket subframes. GM, Holley, or others.
Vega$69 is offline
post #6 of 9 (permalink) Old Nov 16th, 16, 03:16 PM Thread Starter
Rico
So no aftermarket subframe will position the engine to avoid relocating accessories? I see
Ricoshay is offline
post #7 of 9 (permalink) Old Nov 16th, 16, 03:25 PM
Yes with F body accessories. I have done it so I know it works. I also used it with stock LSA accessory drive and LSA oil pan. Pics with the F body accessories here:
https://www.artmorrison.com/gallery/...g2_itemId=1044
This is the only subframe I am aware of that was designed this way. Somewhere on LS1tech.com is a post of pics that I posted with the Sanden compressor mounted low on the Allan Grove bracket.
enroh and Ricoshay like this.
post #8 of 9 (permalink) Old Nov 16th, 16, 03:26 PM
Art Morrison does. I have done it....
Compare the F body accessories to the GTO accessories to assess if they will work. I am guessing they will...
post #9 of 9 (permalink) Old Nov 17th, 16, 02:38 AM
Don, NICE ! I never knew the AM didn't require an accessory change, thats a SWEET subframe
Anyway you look at it, looks like SpeedTech or AM you'll end up at about the same amount in the end ... $7500 or so
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
