LS Engine Radiator - Team Camaro Tech
 8Likes
post #1 of 24 (permalink) Old Dec 7th, 16, 12:05 PM Thread Starter
Patrick
LS Engine Radiator
I bought a radiator for my car. It was made by C and R racing and its model number is 15-11010. They advertise that it is for a first generation Camaro/Firebird that has an LS engine.
This is my problem. The hose inlet and outlet are not on the same side. I guess that I could run the top hose from the driver side over to the passenger side. I am afraid that I could run into some interference problems and it would look cobbled together.
Has anyone on this website run into this problem? How hard was it to fabricate something that would fit? The radiator does not have a shroud so the top hose could fit low. The second photo shows a piece of pipe insulation where the hose could be routed. Any help or suggestions would be greatly appreciated.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
tp_smith is offline
post #2 of 24 (permalink) Old Dec 7th, 16, 12:16 PM
Darin
ilikeike's Avatar
Re: LS Engine Radiator
Are the transmission cooler lines on the driver side also ?
I'd get the correct radiator myself.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 24 (permalink) Old Dec 7th, 16, 12:26 PM
Vega$69's Avatar
LS Rad should have both hose connections on Pass side for a 1st Gen. Also port for steam line should be there
DT likes this.
Vega$69 is offline
post #4 of 24 (permalink) Old Dec 7th, 16, 12:43 PM
If you are running an LS3 crate the water pump outlet is such that it really doesn't make a lot of difference which side it is on. C&R made a custom radiator for me with transmission, steering and oil coolers in it and the connections are the same as yours. I am not worried about it.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 24 (permalink) Old Dec 7th, 16, 01:10 PM
Vega$69's Avatar
Yes it will work. You'll need to take the hose routing into consideration when you do your cold air intake
Vega$69 is offline
post #6 of 24 (permalink) Old Dec 7th, 16, 01:26 PM
Although not the prettiest idea.....it works just fine for me. I tried to keep it as easy as I could with off the shelf parts incase there were ever to be an issue on the road
68 Camaro~LSx ~all motor
post #7 of 24 (permalink) Old Dec 7th, 16, 02:02 PM
Bill
Calpantera's Avatar
They say it will cool OK without a shroud?
Calpantera is offline
post #8 of 24 (permalink) Old Dec 7th, 16, 04:08 PM Thread Starter
Patrick
They say it will cool up to 1000 hp. They have another model that has two fans with a shroud. The shrouded model is rated at 800 hp. The 800 hp model has both the inlet and outlet on the passenger side and is a two pass radiator.
The 1000 hp is a single pass radiator. The steam port is on the driver side. I liked the fact the aluminum was extruded, maybe it would last longer than a standard radiator. The 1000 hp model was on sale during black Friday.
Patrick
tp_smith is offline
post #9 of 24 (permalink) Old Dec 7th, 16, 05:18 PM
Brent
67Rally's Avatar
Depending on which engine you have, you may be able to swap the waterpump out for one that has the outlet on the drivers side.
67Rally is offline
post #10 of 24 (permalink) Old Dec 22nd, 16, 08:27 AM
Corey
Personally, I would return it for the correct radiator. You will have construded angles and bends if you are using a CAI that will feed from the drivers side.
Titan Uranus is offline
post #11 of 24 (permalink) Old Dec 22nd, 16, 08:36 AM
Without knowledge of what water pump the OP is using it is difficult to gauge the magnitude of this potential issue. Corvette LS3 water pump for example would be likely better than the truck water pump shown above...
I have an LSA and a similar radiator from C&R and I am confident it will work fine. The devil is in the details of the application.... These radiators are highly efficient racing radiators with extruded cores and are worth a little head scratching to implement.
post #12 of 24 (permalink) Old Dec 22nd, 16, 08:42 AM
Doug
I would return it for a refund and purchase a Champion LS radiator with 16" electric fan. I think the total is $599.00. You have to check what size inlet and outlet you need. Camaro (67-69)
camarodriver67 is offline
post #13 of 24 (permalink) Old Dec 22nd, 16, 09:19 AM
Vega$69's Avatar
C&R radiators are the best bar none. They build for NASCAR. Not cheap. The one is used in my LS7 car sells for $1800. I got a deal and took the display home at SEMA.
As stated the devil is in the details. CAI. Hose runs etc
Vega$69 is offline
post #14 of 24 (permalink) Old Dec 22nd, 16, 10:36 AM
Greg
I got a superior radiator off of Ebay. $540 + shipping. I am happy with it. Fans work great and seems to cool really well in the limited time I have used it.
zboss86, H20cooled and kcmoney13 like this.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #15 of 24 (permalink) Old Dec 22nd, 16, 11:27 AM
Vega$69's Avatar
I've used this radiator in at least 10 cars both LS and SBC with AC even with blowers. Here in the crazy hot desert they always keep cool, look great and never had a problem with a single one.
zboss86 and Sheck44 like this.
Vega$69 is offline
