Aftermarket Standalone harness vs GMPP - Team Camaro Tech
 4Likes
  • 1 Post By Vega
  • 1 Post By Vega
  • 1 Post By 130fe
  • 1 Post By Vega
post #1 of 11 (permalink) Old Dec 11th, 16, 09:05 AM Thread Starter
DT
Donny
DT's Avatar
I was trying to compare the stand alone engine harnesses between aftermarket (PSI and the like) and the GMPP. I think I like the GMPP harness better. The GM fuse box appears to be much larger than the aftermarket ones and I like the battery lug that is on the GMPP to ease battery connection. Are the aftermarket harnesses just as easy to connect the alternator and battery ? Anyone offer any doubts ,thoughts, concerns ?? Thx
DT is offline
post #2 of 11 (permalink) Old Dec 11th, 16, 09:16 AM
Vega$69's Avatar
Re: Aftermarket Standalone harness vs GMPP
I have used both and I like both equally.
The GM is larger and the 2 added lugs are handy for running AC and Fans. I mount in the battery tray and move the battery to the trunk.
PSI is nice if you want to mount the ECM inside the car.
For me if I do a crate LS I go with GMPP. If built motor PSI.
My buddy just used a GMPP in an LSX swap and happy with it. Hasn't run the car yet.
PSI you get a used ECM. GM you get new.
dhutton likes this.
Vega$69 is offline
post #3 of 11 (permalink) Old Dec 11th, 16, 09:34 AM Thread Starter
DT
Donny
DT's Avatar
Thank you John. I guess no big deal really without the lugs.
DT is offline
post #4 of 11 (permalink) Old Dec 11th, 16, 10:01 AM
Vega$69's Avatar
I use this terminal block wth a fusible link from the battery or starter lug
JEGS Performance Products 10521K: Terminal Block & Bus Bar Kit Includes: Terminal Block 555-10521 | JEGS
Vega$69 is offline
post #5 of 11 (permalink) Old Dec 11th, 16, 11:54 AM Thread Starter
DT
Donny
DT's Avatar
Thanks again John. So I would go from trunk (batt in trunk) direct to one of the lugs on the Jegs bus bar, and then from the bus bar to the starter I take it ? The pos batt cable from trunk would install first on the bus bar terminal.
DT is offline
post #6 of 11 (permalink) Old Dec 11th, 16, 12:20 PM
Vega$69's Avatar
Depends. If you are using a f solenoid the the starter cable run a separate fused #10 to the Jegs t block. Then you can run fans AC etc from that block.
If not the f solenoid the batt cable to starter and wire from starter to t block
Vega$69 is offline
post #7 of 11 (permalink) Old Dec 11th, 16, 12:57 PM Thread Starter
DT
Donny
DT's Avatar
Yes a F solenoid. Thx again.
DT is offline
post #8 of 11 (permalink) Old Dec 11th, 16, 01:37 PM
Vega$69's Avatar
Ok then run a wire from the batt side of the solenoid with a fuse or fusible link the the TBlock.
That way your radio etc will have constant power and will retain settings.
DT likes this.
Vega$69 is offline
post #9 of 11 (permalink) Old Dec 11th, 16, 02:06 PM
Chris
130fe's Avatar
Another thing to think about is the GMPP uses an E67 PCM where as some of the others use E38s. Either one will work though. I have the GMPP and haven't had any issues with mine.
DT likes this.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #10 of 11 (permalink) Old Dec 12th, 16, 11:54 AM Thread Starter
DT
Donny
DT's Avatar
Also, PSI does NOT do a "performance tune" so they use stock parameters and remove some things, but that's it. All good info, thanks guys.
DT is offline
post #11 of 11 (permalink) Old Dec 12th, 16, 12:14 PM
Vega$69's Avatar
Base tune on the GM set up too
DT likes this.
Vega$69 is offline
