GMPP serpentine kit - Team Camaro Tech
 3Likes
  • 1 Post By zboss86
  • 2 Post By zboss86
post #1 of 14 (permalink) Old Jan 4th, 17, 08:13 PM Thread Starter
Shad
zboss86's Avatar
GMPP serpentine kit
I know most of you guys use the vette style system.(19155067)
I was looking at 19155066 because it doesn't hang the A/C way out to the side. I thought it was an Fbody setup, but it's actually a Cadillac CTSV.
It states that it won't work with with production cast iron blocks. Anyone know the reason? I'm also curious if it has the truck, camaro, or vette spacing...
http://paceperformance.com/images/M62948675.png
My Mistress rebuild...
zboss86 is offline
post #2 of 14 (permalink) Old Jan 5th, 17, 04:32 AM
Vega$69's Avatar
Re: GMPP serpentine kit
Compressor won't clear the subframe
Vega$69 is offline
post #3 of 14 (permalink) Old Jan 5th, 17, 04:41 AM Thread Starter
Shad
zboss86's Avatar
Correct, it won't clear a stock subframe. But I've seen it work with a notched frame. My subframe is notched and I can move my motor mount back if need be...
I'm mainly curious why it says it won't work with an iron block.
zboss86 is offline
post #4 of 14 (permalink) Old Jan 5th, 17, 04:49 AM
Vega$69's Avatar
Looked at the description I don't see where it says won't work with iron block
Vega$69 is offline
post #5 of 14 (permalink) Old Jan 5th, 17, 05:04 AM
Says here it will not work with LS327 iron block, not all iron blocks:
Chevrolet Performance 19155066: F-Body Style Accessory Drive System With Power Steering, With A/C | JEGS
I am guessing one or more mounting holes are missing.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 14 (permalink) Old Jan 5th, 17, 05:09 AM Thread Starter
Shad
zboss86's Avatar
Don, that's what I'm guessing. There's two holes missing on the lower driver side of the iron block. One can be drilled and tapped, the boss is missing all together on the other, so it can't be added. I'm curious if it's one or both of those holes.
zboss86 is offline
post #7 of 14 (permalink) Old Jan 5th, 17, 05:16 AM
DT
Donny
DT's Avatar
Why not use the GM set-up 19257325 for 200 or more bucks less ?? The SD-508 AC compressor doesn't stick out that far does it ?
DT is offline
post #8 of 14 (permalink) Old Jan 5th, 17, 05:32 AM Thread Starter
Shad
zboss86's Avatar
Donny,
Doesn't the Holly set ups put the compressor on the upper passenger side?
It's not a money issue(not that I have plenty)... I actually have a pretty nice March style track set up. It's a location issue. I'm looking at running a large turbo in the upper passenger side area where the Holley System and most other aftermarket systems place the A/C compressor. I really prefer to put the compressor tucked down low.
zboss86 is offline
post #9 of 14 (permalink) Old Jan 5th, 17, 05:58 AM
DT
Donny
DT's Avatar
Originally Posted by zboss86 View Post
Donny,
AAHH, I initially thought the Holley set up was 600, It looks like the 600 kit was actually GM. I was just looking to save you 200 bucks LOL. I see now why you need the A/C lower. How about the truck set-up ? One of the set-ups mount the A/C on the lower pass side, can't remember which though.
DT is offline
post #10 of 14 (permalink) Old Jan 5th, 17, 06:17 AM Thread Starter
Shad
zboss86's Avatar
The truck set up throws the alternator above my fender about an inch. I think it's b/c I used half height subframe bushings. I may dig around see if I can find a used 4th gen Fbody kit.
DT likes this.
zboss86 is offline
post #11 of 14 (permalink) Old Jan 5th, 17, 11:44 AM
Rich
I have the Drive Junky (Drive Junky)front setup on my LS swap, it is very nice and it comes in a high and low setup. Its not the cheapest thing out there but the quality is hard to beat.
Rich
1967 SS350, Under construction.
H20cooled is offline
post #12 of 14 (permalink) Old Jan 5th, 17, 12:32 PM Thread Starter
Shad
zboss86's Avatar
Rich
Rich
Rich, that's a good looking kit and I've seen others brag on them. It's probably one of my favorites... But even with the version low mount version, they run the alternator up top.
I'm about dead set on running the 4th gen f-body serpentine set up. I've ordered a dirty dingo lower A/C mount to that runs a Sanden SD7B10 Mini A/C Compressor in the lower quadrant that's will work with the truck, vette, and the F-body offset.
It's a smaller sanden compressor that Vintage air says they run on a lot of their front runner set ups. So if I can make it fit, I'll scrounge up the brackets and stuff from a 4th gen Camaro.
LS swap conversion Gen 3- Gen 4 Low Mount A/C Bracket SD7B10
zboss86 is offline
post #13 of 14 (permalink) Old Jan 11th, 17, 05:22 AM Thread Starter
Shad
zboss86's Avatar
Wanted to post about some things I've read about the GMPP 19155066 kit.
It's advertised the CTSV accessory drive. I've been told it will work with the iron block if you drill/tap one boss on the driver side. It puts the accessories in a similiar configuration as the 4th gen camaros, but.... it has a vette offset. The vette offset will throw the A/C compressor and the Alternator back towards the motor mounts. So even with a notched first gen subframe, your compressor will be extremely close if not hitting the motor mounts. It will hit the holley conversion mounts, it might clear others(doubtful)
zboss86 is offline
post #14 of 14 (permalink) Old Jan 11th, 17, 05:46 AM Thread Starter
Shad
zboss86's Avatar
So, putting alternator and a/c compressor in the lower quadrants isn't for the faint of heart, but it can be done. What I'm looking to try...
2010 accessory drive puts the accessories in a similar configuration, but with the truck offset. Doing this will shift my a/c compressor and alternator further forward. The good thing is, you can still purchase the 2010 accessory brackets/bolts straight through GM.
One thing I did change up was that I bought the dirty dingo A/C relocation bracket that uses the Sanden SD7B10 Mini A/C compressor to get me more room. It will mount the smaller compressor with the vette, 4thgencamaro, or the truck offset.
You can see how tight it is with the Holley Motor mounts. Other relocation mounts with adapter plates that use the big block stands would raise the engine some would provide a lot more room. But I really like how the Holley mounts are designed and they set the engine low. It definitely makes it more of a challenge.
Since that worked, I purchased the 2010 camaro alternator bracket from GM $35 to see how how everything clears on the driver side.
DT and dhutton like this.
zboss86 is offline
