Any luck with stock manifolds and Holley 12618HKR swap mounts?? - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 19th, 17, 12:52 PM Thread Starter
Ryan
Hi guys,
I'm doing an LS swap on a 1968 Camaro, and was hoping to get away without buying the headers yet. Any one have any luck fitting any stock manifolds around the steering box? I have a set of 00-02 fbody manifolds with the O2 bung shaved, and I only have about 1/8" clearance. Too close to run it that way. I found a picture a while back of someone using an Alpha H3 Driver's manifold that looked like it may fit without modifications.
Thanks,
Ryan
Project: 1968 Camaro 5.3, T56, Z51 brakes, 12 bolt, etc.
ryeguy2006a is offline
post #2 of 14 (permalink) Old Jan 19th, 17, 02:45 PM
Re: Any luck with stock manifolds and Holley 12618HKR swap mounts??
Originally Posted by ryeguy2006a View Post
Hi guys,
Thanks,
Ryan
A 600 steering box will buy you some room.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 14 (permalink) Old Jan 19th, 17, 03:23 PM Thread Starter
Ryan
I already upgraded to the Jeep Grand Cherokee box for the LS swap, but are any of the 600 boxes metric and quick ratio?
post #4 of 14 (permalink) Old Jan 19th, 17, 03:31 PM
Not sure about the threads. Turn-One has them but they are not inexpensive. Quick ratio with rack and pinion valving. They might be in stock at DSE too.
post #5 of 14 (permalink) Old Jan 20th, 17, 05:12 AM Thread Starter
Ryan
Thanks Don. I will take a look at them.
post #6 of 14 (permalink) Old Jan 21st, 17, 11:38 AM
Anne
Have you checked with anyone on LS1tech about using LS3 vette manifolds ?
They are on ebay fairly cheap.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #7 of 14 (permalink) Old Jan 23rd, 17, 10:56 AM Thread Starter
Ryan
Lawrence454, Yes I failed to mention that I tried a set of LS3 manifolds off of a crate motor that a buddy had. Unfortunately they fit worse than the LS1 manifolds I have.
post #8 of 14 (permalink) Old Jan 23rd, 17, 11:38 AM
Shad
zboss86's Avatar
Truck manifold fit fine if you turn them around, flip them upside down, and add a hair dryer...
My Mistress rebuild...
zboss86 is offline
post #9 of 14 (permalink) Old Jan 23rd, 17, 11:54 AM Thread Starter
Ryan
Yes Sir! Unfortunately, I want to get paint first.
post #10 of 14 (permalink) Old Jan 30th, 17, 12:25 PM
Shad
zboss86's Avatar
I tried a LS4 manifold... It doesn't work either. I have a trail blazer manifold, it's the same as a truck(unless it was swapped at the salvage yard).
Last edited by zboss86; Jan 30th, 17 at 12:30 PM. Reason: I see you already noted using a vette manifold
zboss86 is offline
post #11 of 14 (permalink) Old Jan 31st, 17, 05:06 AM Thread Starter
Ryan
I think what I am going to do zboss, is similar to what you did on your truck manifold and notch the fbody manifold I have. I think right now it makes the most sense.
post #12 of 14 (permalink) Old Jan 31st, 17, 05:42 AM
Shad
zboss86's Avatar
I stand corrected on the trailblazer manifold. The trailblazer engine I got from the salvage yard had truck manifolds on it. My buddy was swapping out a trail blazer engine at his shop and I stole his extra manifolds. The tubes are smaller and more important, they hug closer to the block. You can see below the small window I've cut into the manifold to make it work. If you had a smaller power steering box, it wouldn't have needed the window cut. I also cut the triangle collector off the bottom.
Below is a plethora of manifolds I've tried... Vette manifold, truck manifold,LS4 manifold, I didn't have any camaro manifolds to try.
zboss86 is offline
post #13 of 14 (permalink) Old Jan 31st, 17, 05:56 AM Thread Starter
Ryan
The only other manifold that I have found that is almost a unicorn is the Alpha H3 manifold left/driver's side (P/N 12598548). It's hard to find pictures of it, but I think if I could find one it would work.
If anyone here happens to have one and would like to sell or ship it to me for a trial I would greatly appreciate it!
post #14 of 14 (permalink) Old Jan 31st, 17, 05:57 AM Thread Starter
Ryan
Not my picture, but I found this online. Here is a guy too who has an LS motor in a '57 Bel Air that has the steering box in a similar position.
H3 Manifolds? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
