GMPP LS3 Harness - Team Camaro Tech
 11Likes
post #1 of 45 (permalink) Old Mar 17th, 17, 07:32 AM Thread Starter
DT
Donny
DT's Avatar
GMPP LS3 Harness
Guys, I was thinking of using a Bulkhead connector on the firewall for my LS3 GMPP controller harness. Anyone use one ??
DT is offline
post #2 of 45 (permalink) Old Mar 17th, 17, 07:37 AM
Shawn
Re: GMPP LS3 Harness
I pulled all the stuff that needed to go into the interior through the old gas pedal hole. You have to pull a few connectors apart then re-ssemble to get everything through but that is a simple enough procedure.
DT likes this.
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #3 of 45 (permalink) Old Mar 17th, 17, 07:45 AM
Vega$69's Avatar
Just for the pedal and ODB or for the ECM?
For Pedal and OBD I go thru the old pedal hole too
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 45 (permalink) Old Mar 17th, 17, 07:52 AM Thread Starter
DT
Donny
DT's Avatar
I wanted a clean install and was thinking it would be easier if I had a bulkhead connector on the firewall. The ECM and Fuse box will be installed in the battery tray. Now that I think about it, How many wires are needed in the interior ??? I may not need a bulkhead connector at all.
DT is offline
post #5 of 45 (permalink) Old Mar 17th, 17, 08:19 AM
Vega$69's Avatar
Only wires that go inside are pedal and OBD. Then you may have the tach wire which you can go thru the pedal hole or use the factory bulkhead connector as a pass thru.
DT likes this.
Vega$69 is offline
post #6 of 45 (permalink) Old Mar 17th, 17, 08:24 AM Thread Starter
DT
Donny
DT's Avatar
I was trying to figure out how to hide the wires going to the ECM and fuse box. How do I get to the passenger fender (under fenderwell) and to battery tray. I was trying to avoid routing across firewall/cowl area from engine side.
DT is offline
post #7 of 45 (permalink) Old Mar 17th, 17, 08:48 AM
Vega$69's Avatar
Under heater box and pull the fuse box and ECM connectors through inner fender,
There is not enough room for both the fuse box and the ECM in the battery tray. I mount the ECM to the inner fender behind the battery tray (between the batt tray and fender) then the fuse box in the battery tray.
There are no holes or tabs on the fuse box to mount it. I've found the best method is industrial strength 2" Velcro.
Vega$69 is offline
post #8 of 45 (permalink) Old Mar 17th, 17, 08:53 AM Thread Starter
DT
Donny
DT's Avatar
Thanks John. I will be running vintage air. So the passenger side of firewall is somewhat smooth, I added a plate. Here is what I had planned for the fuse box and ECM. Again, I'm trying to avoid running any wire from engine to passenger side on firewall. I would love to hide the wires.
DT is offline
post #9 of 45 (permalink) Old Mar 17th, 17, 09:02 AM
Vega$69's Avatar
if you keep them low on the firewall you don't really see them. I would think about re-wrapping them with power braid instead of the plastic split loom
Vega$69 is offline
post #10 of 45 (permalink) Old Mar 17th, 17, 09:13 AM Thread Starter
DT
Donny
DT's Avatar
OK, thank you.
DT is offline
post #11 of 45 (permalink) Old Mar 17th, 17, 09:36 AM
I use the Ironworks bracket to mount the ECM up under the fender above the battery box where it also clears the front cocktail shaker. I fabricated a bracket to mount the fuse block to the core support above the battery tray. The Vaporworx controller mounts to the botttom of the bracket. You can split the fuse block apart and bolt the bottom shell to the bracket. It is tight with the diagonal fender brace but it will fit right in there. The Entropy fan controller also mounts to the core support in the same area.
LS2-LS3-LS7-LS9 ECU Bracket
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #12 of 45 (permalink) Old Mar 17th, 17, 09:40 AM
Vega$69's Avatar
Originally Posted by dhutton View Post
I use the Ironworks bracket to mount the ECM up under the fender above the battery box. I fabricate a bracket to mount the fuse block to the core support above the battery tray. The Vaporworx controller mounts to the botttom of the bracket. You can split the fuse block apart and bolt the bottom shell to the bracket. It is tight with the diagonal fender brace but it will fit right in there. The Entropy fan controller also mounts to the core support in the same area.
I just ordered their pedal bracket today to give it a try on the LS swap I'm doing in the 68 at this time
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 45 (permalink) Old Mar 17th, 17, 09:44 AM
I used it. It places the gas pedal quite high, flush with the brake pedal. I would have preferred it if sat 1" behind the brake pedal, more like most cars.
DT likes this.
post #14 of 45 (permalink) Old Mar 17th, 17, 10:03 AM Thread Starter
DT
Donny
DT's Avatar
I see guys using a C6 Corvette (2005-2013) pedal as well. The Corvette pedal looks more like an OEM Camaro pedal IMHO.
DT is offline
post #15 of 45 (permalink) Old Mar 17th, 17, 10:23 AM
I see guys using a C6 Corvette pedal as well. The Corvette pedal looks more like an OEM Camaro pedal IMHO.
Make sure they interchange. They are not all the same resistance as far as I know. That is not to say they won't work but ECM programming may be required.
Pedal looks OK to me, I am just not happy with the location of the pedal with the Ironworks bracket.
DT likes this.
