ZL1 Supercharger on an LSX - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 17th, 17, 02:45 PM Thread Starter
Shawn
So right now I have a verbal agreement to purchase a lower portion of a ZL1 supercharger, and right now am gathering prices for the upper portion plus other supporting items like pulleys, etc. The blower is brand new still in the box and if everything goes well with what I have planned I could have it installed for half the price of a brand new ZL1 blower kit from GM. I'm sure there will be the question of why don't I buy a different kit which is less expensive than the GM kit and makes more power, while true if I was buying complete kits I'm getting the supercharger unit for a great price and am think I'll be quite content if I can make 600 hp with it which I don't think is unreasonable.
Now the reason for the thread is to make sure I have everything figured out correctly before I fork over the money for the unit. I know I can get a pulley kit from LSX concepts to take care of spinning the blower, and can get the upper portion (and if needed the fuel rails) from a local dealer. I am thinking I should be able to take my PCV connetions off my existing manifold and putting it onto the blower manifold however there are several other connections on the supercharger that I am not sure about.
Do I need to connect the supercharger inlet and outlet pressure sensors? Do I need the evaporator purge control valve? Is there any modifications required on my LS3 swap harness to make this work?
I tried doing a search online but all I got was a bunch of threads where someone would ask about bolting a ZL1 supercharger onto a LS3 and then others would just ask why not go with a different manufacturer. So is anyone able to help me out with my questions?
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #2 of 13 (permalink) Old Mar 19th, 17, 02:56 PM
Jason
Re: ZL1 Supercharger on an LSX
Yes
No
Yes. You will need a 3 bar map, fuel upgrades to feed your projected power levels and a dyno tune.
You will also need more Im sure, don't know your current setup but if you can get an itemized list of the complete kit from GM, you'll know what you need to add. Unless you really know what you are doing I would advise against trying to piece something together to save a few bucks. All the pieces add up quick and you increase your chances of something going wrong. In a supercharged setup that means new motor. Go with an engineered setup or copy it with an itemized parts list. Hope this helps
Bricks67 is offline
post #3 of 13 (permalink) Old Mar 20th, 17, 07:09 PM Thread Starter
Shawn
Yes
This doesn't really give me a fully answer. Will this be something needed for tuning or is it something that is purely for showing the boost generated? Basically why are these sensors required when I don't really have provisions for them in my harness.
No
Good to know that I do not need the evap purge control valve. I believe the controller kit I bought utilizes the 3 bar map sensor already and my fuel system can handle up 750 hp for boosted applications so those areas are fine. I'm not trying to piece anything together the only items I am not getting from GM are the tensioner, drive pulley and belt which I am planning to get from LSX concepts. The rest will be new pieces (including the lid and exchanger, fuel rail, hose kit, etc) direct from a dealer.
Thanks for your help so far though! Looking forward to the response on my question above.
Build Thread:
stugger is offline
post #4 of 13 (permalink) Old Mar 20th, 17, 07:35 PM
Vega$69's Avatar
You can buy a complete take off ZL1 blower for less then just buying the lower and piecing together the rest.
You don't need to go 3 bar. You can go with MAF tuning an 42# injectors and can get 600 hp easy with a mild blower cam with 6 psi boost
Th challenge will be finding a good spot for the intercooler
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 13 (permalink) Old Mar 20th, 17, 09:00 PM Thread Starter
Shawn
The problem with a take off is that they can have the faulty spring in the isolator, this is a new unit with a solid isolator. I was thinking that the MAF tuning would be sufficient but I couldn't say for sure as this is new territory for me. All I'm looking for is around that 600-650 rwhp range and I think I'd be way more than satisfied. Could I not do the intercooler on the front of the radiator core support? I don't have any A/C components in the car so I don't really have to worry about space in the front.
Build Thread:
stugger is offline
post #6 of 13 (permalink) Old Mar 21st, 17, 01:58 PM
Jason
Sensors are there for tuning purposes. including 3 bar map. Talk to your tuner on how he would want the engine setup to produce the best tune possible. Lots of different ways to tune a car. Factory tune is ve blended and produce the best tune (throttle response, idle, low speed and wot) in my opinion. Additional sensors while technically not needed, add information that a tuner can log and make changes accordingly. They are cheap and easy to install. Rods and pistons are not. Hope this helps.
Bricks67 is offline
post #7 of 13 (permalink) Old Mar 21st, 17, 02:06 PM
Jason
Intercooler is in the lid of these blowers. Heat exchanger can go in front of radiator.
Bricks67 is offline
post #8 of 13 (permalink) Old Mar 21st, 17, 03:48 PM Thread Starter
Shawn
Ok perfect that fully answers my question, thank you so much for the help! I am running an LSX series crate engine that has forged pistons to handle the boost, which I believe it is about 9 psi max from the blower but I wont be looking for any max power set ups. Like I said above if I can make 600-650 rwhp I would be way more than happy with that. I will have to call up some tuners to see what they would like to see but the sensors will still be there for future use even if I don't incorporate them into my setup.
Build Thread:
stugger is offline
post #9 of 13 (permalink) Old Mar 21st, 17, 07:15 PM
Vega$69's Avatar
Your stated goal is approx 725 HP flywheel. You get approx 20 HP per # of boost. Ideally you should rum lower compression for a blower motor.
I ran 6 psi with my Maggie on my LS1 Vette with heads, cam, long tubes and conservative tune with 10.5 compression. Made 505 rear wheel with an auto tranny. With lower comp I could have turned up the boost to 9 and made 50-75 hp more rear wheel. The LSX with I assume better LS3 heads will do better.
What compression are you planning to run?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 13 (permalink) Old Mar 21st, 17, 07:31 PM
Jason
No problem. You could double the boost and be ok as long as you feed it enough fuel. These LS motors are awesome. Id run the biggest heat exchanger you can fit up front. Find the dimensions online and make cardboard mockups to check fitment. Afco makes a nice one. Keeps the intake air charge temps down.
Bricks67 is offline
post #11 of 13 (permalink) Old Mar 21st, 17, 07:50 PM
Vega$69's Avatar
Yes you're correct so long as you static compression and IATs do not cause detonation.
With the knock sensors it will pull timing and kill power. If you're off and run lean say goodbye to #7. Adding fuel alone will not do the trick.
Also good tuning across the band is essential.
Lots of guy go SD. Why? Because imho they don't know how to tune. I would maf tune so you don't have concerns with atmospheric changes.
Vega$69 is offline
post #12 of 13 (permalink) Old Mar 22nd, 17, 04:39 AM
C&R Racing sells a heat exchanger with brackets for a first gen that works with the hood latch etc. Works with Vintage Air too.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #13 of 13 (permalink) Old Mar 26th, 17, 09:40 PM Thread Starter
Shawn
The compression on my motor is 9:1 so I am looking to run the 9 psi at WOT, the tune will be conservative first and foremost. While I'd love to have 600-650 rwhp I will sacrifice that "goal" to make sure everything will run properly and survive. In thinking about this over the weekend I think the biggest problem I will have will be wiring in the bypass solenoid that comes with the supercharger, trying to think of solutions for that cause it would be nice to have for cruising.
I will keep them in mind, especially since Vintage Air is in the plan for the future. I picked up the supercharger this weekend so now I'm working to get the rest of the parts I need to install it!
Build Thread:
stugger is offline
