Sway Bar Clearance Question - Team Camaro Tech
 2Likes
  • 1 Post By 67Rally
  • 1 Post By 67Rally
post #1 of 8 (permalink) Old Mar 19th, 17, 01:50 PM Thread Starter
Apprentice
Derrick
I am installing a 6.0 into my 1969 Camaro and I am running into clearance issues with the sway bar. I am using Dirty Dingo Double D mounting plates and when I position them to clear the steering linkage, I run into issues with the sway bar. I have a stock subframe. I could not find it anywhere but is the a common issue? Is the fix just to go with a different sway bar?
weasle is offline
post #2 of 8 (permalink) Old Mar 19th, 17, 02:51 PM
DT
Donny
DT's Avatar
Re: Sway Bar Clearance Question
What vehicle did that engine come out of ?? Can you change the balancer to a smaller one ??
DT is offline
post #3 of 8 (permalink) Old Mar 19th, 17, 03:47 PM Thread Starter
Apprentice
Derrick
It came out of a 2001 chevy 2500 HD truck.
weasle is offline
post #4 of 8 (permalink) Old Mar 19th, 17, 05:15 PM
DT
Donny
DT's Avatar
Isn't the corvette balancer smaller??
DT is offline
post #5 of 8 (permalink) Old Mar 19th, 17, 05:30 PM
Brent
67Rally's Avatar
What frame mounts do you have? Could you go with a taller mount?
DT likes this.
67Rally is offline
post #6 of 8 (permalink) Old Mar 20th, 17, 01:49 PM Thread Starter
Apprentice
Derrick
Thanks guys, I will look into these options.
weasle is offline
post #7 of 8 (permalink) Old Mar 20th, 17, 02:17 PM
Brent
67Rally's Avatar
I have the "tall & narrow" '69 Camaro mounts for a 302/350. Part #'s 3945507 and 3945508.
FWIW, they work with my LQ9, Dirty Dingo Sliders, Energy Suspension (3-1117G) poly motor mounts, and Hotchkis front sway bar.
DT likes this.
67Rally is offline
post #8 of 8 (permalink) Old Mar 20th, 17, 05:13 PM
Had this issue when I went to a 400 (8" balancer). My "quick fix" was to add spacers under the sway bar frame mounts. So "if" this was going to be an issue....It was already addressed
I took the bracket off, made a rectangle 1/2" thick spacer, drilled the 2 holes in them so they wouldn't fall out , and added some longer bolts...been good for a long time now.
68 Camaro~LSx ~all motor
