DBW bracket install - Team Camaro Tech
 2Likes
post #1 of 16 (permalink) Old Apr 2nd, 17, 09:48 AM Thread Starter
DT
Donny
DT's Avatar
DBW bracket install
I have the DBW pedal installed. Turns out the stock bracket that comes with the pedal is not that bad after all.
ID:	179714   Click image for larger version
DT is offline
post #2 of 16 (permalink) Old Apr 2nd, 17, 09:58 AM
shawn
Re: DBW bracket install
Looks good. I bought the Ironworks bracket but after some mock up I think your solution is a lot better.
frog7151 is offline
post #3 of 16 (permalink) Old Apr 2nd, 17, 10:01 AM Thread Starter
DT
Donny
DT's Avatar
I was going to purchase the Ironworks bracket until I saw Johns picture of it and you have to use the master cylinder bolts to attach it to. The stock bracket turned out very good. 3/4 inch spacer on the left bolt, 1 1/4 inch spacer on top right bolt and I welded up a little fab piece for the lower right mounting bolt.
DT is offline
post #4 of 16 (permalink) Old Apr 2nd, 17, 11:21 AM
Vega$69's Avatar
I bought the Street Machine bracket on eBay.
Looks like it's going to work well. Only $25
Vega$69 is offline
post #5 of 16 (permalink) Old Apr 2nd, 17, 11:54 AM Thread Starter
DT
Donny
DT's Avatar
Nice, I was wondering if it was any good.
DT is offline
post #6 of 16 (permalink) Old Apr 2nd, 17, 01:39 PM
Steven
stamatisg1977's Avatar
i have the detroit speed brackel
Detroit Speed, Inc. - Engine/Driveline - C6 Throttle Pedal Bracket
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #7 of 16 (permalink) Old Apr 2nd, 17, 02:06 PM
Vega$69's Avatar
Originally Posted by stamatisg1977 View Post
Does not work with the GMPP Cadillac pedal
DT likes this.
Vega$69 is offline
post #8 of 16 (permalink) Old Apr 2nd, 17, 02:45 PM
Steven
did not know that
thank you
Tremec TKO 600
post #9 of 16 (permalink) Old Apr 2nd, 17, 04:15 PM Thread Starter
DT
Donny
DT's Avatar
How much pedal travel is needed ?? Anyone have any idea? Just curious. I'm 3 inches from the floor.
DT is offline
post #10 of 16 (permalink) Old Apr 2nd, 17, 04:34 PM
Vega$69's Avatar
Travel is only about a 1"-1 1/2"
DT likes this.
Vega$69 is offline
post #11 of 16 (permalink) Old Apr 27th, 17, 10:13 AM
shawn
John how did this workout for you?
frog7151 is offline
post #12 of 16 (permalink) Old Apr 27th, 17, 12:37 PM
Vega$69's Avatar
It worked well on Steve's car. There is one existing hole the you can open up and use for the bottom hole on the bracket then drill 2 holes and bolt thru the firewall.
Vega$69 is offline
post #13 of 16 (permalink) Old Apr 27th, 17, 02:41 PM
foreverlookin's Avatar
Works too well! Tickets should start the more I drive it!
foreverlookin is offline
post #14 of 16 (permalink) Old Apr 28th, 17, 04:54 AM
shawn
Thanks John. I hope to get mine installed this weekend.
frog7151 is offline
post #15 of 16 (permalink) Old Apr 28th, 17, 05:03 AM
Vega$69's Avatar
We are using the same bracket in Robs 67 tomorrow. I'll take some pictures
Vega$69 is offline
