Rob's 67 Going with LS3/480 - Team Camaro Tech
 9Likes
post #1 of 16 (permalink) Old Apr 24th, 17, 06:56 AM Thread Starter
Vega$69's Avatar
Started the swap Saturday.
Away with the 350 and in with the LS3/480. He already had a TKO600.
LS and tranny in and with the driveshaft and most of the work is complete underneath.
The Hooker Headers bolted on easy with plenty of clearance around the steering box.
Schedule is to have the new Tanks Inc. EFI tank and fuel system along with the radiator and everything finished next weekend. Then I'll wire it up and fire it.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #2 of 16 (permalink) Old Apr 24th, 17, 08:05 AM
1Slow64
Re: Rob's 67 Going with LS3/480
Looking good.
My 69 X66 project.
69X66 is offline
post #3 of 16 (permalink) Old Apr 24th, 17, 03:04 PM
How about the hired help this past weekend! Man we kicked butt! LOL!!
SB60 is offline
post #4 of 16 (permalink) Old Apr 24th, 17, 04:15 PM Thread Starter
Vega$69's Avatar
You got Free Lunch and Beer.
DT likes this.
Vega$69 is offline
post #5 of 16 (permalink) Old Apr 25th, 17, 08:55 PM Thread Starter
Vega$69's Avatar
Plan to do the fuel system after work tomorrow. Then knock out the new radiator install. That will just leave the hydraulic clutch and pedal installation and the wiring. Well and the cold air intake. Using the Spectre set up.
Hope to fire it up this weekend if all goes as planned.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #6 of 16 (permalink) Old Apr 26th, 17, 06:06 PM
Joe
Rob's going to be one happy camper when you are done with that.
Z282NV is offline
post #7 of 16 (permalink) Old Apr 26th, 17, 08:00 PM
Cole
This looks like a super clean build! Keep it up
CraftsmanCole is offline
post #8 of 16 (permalink) Old Apr 27th, 17, 03:33 AM
Greg
pittpens24's Avatar
John you make it look so easy. Great job man!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #9 of 16 (permalink) Old Apr 27th, 17, 06:46 AM Thread Starter
Vega$69's Avatar
Installed the fuel tank yesterday afternoon
To make it easier.
I install the wiring and leave the wires long. I then take my 20' length of fuel line and attach one end to the supply fitting and the other to the return. I mark a small "S" and "R" with a felt pen on the tank to indicate which side is which. Also install the vent hoses on the pump and the tank and run them to the Y connector if using one rollover vent or 2 lines if going with 2 vents.
Pop the tank into place and secure it with the straps. Now you can mount the Corvette Reg/Filter and cut the hoses to length from the tank to the reg. and route the line from the reg to the fuel rail. I run the fuel line on the drivers side and the 12v wire from the pump on the pass side.
For the PS pump use the Earl's PS extended fitting. This gets the AN connector clear of the PS pulley. Your original high pressure hose should be long enough. Have a local hose shop install a 6AN hose connector and you're done. For the low pressure return side the hose is too short. You can use the original fitting and longer 3/8" ps hose. hose clamps are all you need to connect to the fitting and PS reservoir.
https://www.summitracing.com/parts/e...FYFqfgodJBcKzg
Name:	PS Fitting.jpg
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 16 (permalink) Old Apr 29th, 17, 06:35 PM Thread Starter
Vega$69's Avatar
Fuel System - Done
Cooling System - Done
Tomorrow will install the hydraulic clutch master and pedal, The ECM and harness and fire it up.
Total time so far - Last Saturday and Sunday, 2 evenings for a couple hours and today.
After tomorrow's test drive We still need to have the exhaust welded and I'm converting the heater core to a BBC core. The SBC heater core hose fittings will not clear the engine on the pass firewall side.
I'll do a thread on the heater core conversion using the SBC cover without having to remove it for those interested.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #11 of 16 (permalink) Old Apr 29th, 17, 07:24 PM
Brad
John, sent you a PM looking for a shopping list. Thanx!
bwarren is offline
post #12 of 16 (permalink) Old Apr 29th, 17, 07:52 PM Thread Starter
Vega$69's Avatar
Let me know what you have already and what your plans are.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 16 (permalink) Old Apr 29th, 17, 07:56 PM Thread Starter
Vega$69's Avatar
Just to add. Robs been here helping with his swap along with my buddies Steve and Randy as well as my son Wes for a few hours.
I put the LS3/480 TKO600 into steves 69 almost 3 years ago and it still runs perfect.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #14 of 16 (permalink) Old Apr 29th, 17, 08:15 PM
Brad
Right now I have a 350 (77-79 truck motor) with a TKO-600 and 3.73. Looking to do an LS3/480 swap (as you did for Steve - foreverlookin). Looking for a list of parts / part#s I'll need. Thanx for your help.
Sorry, not looking to hijack this thread - just jealous!!
bwarren is offline
post #15 of 16 (permalink) Old Apr 30th, 17, 08:15 PM Thread Starter
Vega$69's Avatar
Fired up today as planned.
Runs great.
8 calendar days including 2 weekends and 2 evenings for a couple hours.
Yahoo!
130fe, DT and 1968RallySport like this.
Vega$69 is offline
