Clam shell mounts/Holley - Team Camaro Tech
 3Likes
  • 1 Post By dhutton
  • 1 Post By Bricks67
  • 1 Post By Vega
post #1 of 14 (permalink) Old May 6th, 17, 02:09 PM Thread Starter
DT
Donny
DT's Avatar
What size motor mount bolts are used with the LS Holley motor mounts and clam shells ?? I'm coming up with 1/2" x 5".
DT is offline
post #2 of 14 (permalink) Old May 6th, 17, 07:08 PM
Vega$69's Avatar
Re: Clam shell mounts/Holley
I'll check for you I just put some on Steve's 68
Vega$69 is offline
post #3 of 14 (permalink) Old May 6th, 17, 09:07 PM Thread Starter
DT
Donny
DT's Avatar
Thx John.
DT is offline
post #4 of 14 (permalink) Old May 7th, 17, 05:31 AM
Vega$69's Avatar
Bolts
https://www.summitracing.com/parts/rnb-81101
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 14 (permalink) Old May 7th, 17, 05:33 AM Thread Starter
DT
Donny
DT's Avatar
Thank you John !
DT is offline
post #6 of 14 (permalink) Old May 7th, 17, 05:40 AM
Vega$69's Avatar
Originally Posted by DT View Post
Thank you John !
I used Energy Suspension Poly Inserts. Was a pain getting the second bolt to line up. Then I read the "Hint" in the instructions that say to put a little lube or dish washing detergent on the insert to help it seat. Lol
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 14 (permalink) Old May 7th, 17, 06:15 AM Thread Starter
DT
Donny
DT's Avatar
You know I did come across them as well. I have the standard Anchor mounts#2292. Strange that I can get a 1/2 inch bit through the mount hole and the adapter mount from Holley. The #81101 bolts are 7/16's.
DT is offline
post #8 of 14 (permalink) Old May 7th, 17, 06:33 AM
The Holley instructions tell you the bolt size....
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #9 of 14 (permalink) Old May 7th, 17, 07:54 AM Thread Starter
DT
Donny
DT's Avatar
No Sir.
DT is offline
post #10 of 14 (permalink) Old May 7th, 17, 11:07 AM
No Sir.
I am going to check my instructions because I am sure I ordered the bolts based on their stated size. Of course it goes without saying I am getting senile...
DT likes this.
post #11 of 14 (permalink) Old May 7th, 17, 12:09 PM
Ok I checked my instructions and I can't find it either... I used 7/16 bolts, no idea why...
post #12 of 14 (permalink) Old May 7th, 17, 05:31 PM
Jason
Just FYI. Install the drivers side motor mount bolt from the front. If you install from the rear like I did it is impossible to remove. Had to change out my headers and ended up cutting the bolt to remove. Would have been much easier had I just installed from the front the first time.
DT likes this.
Bricks67 is offline
post #13 of 14 (permalink) Old May 7th, 17, 07:24 PM
Vega$69's Avatar
Well I posted the correct bolt as I had to do a little research to determine the correct bolts.
I just looked for the bolts based on the model years clamshells were used.
DT likes this.
Vega$69 is offline
post #14 of 14 (permalink) Old May 8th, 17, 12:10 PM Thread Starter
DT
Donny
DT's Avatar
Thanks everyone.
DT is offline
