First gen T56 shifter location, Holley mounts - Team Camaro Tech
post #1 of 5 (permalink) Old May 26th, 17, 06:08 AM Thread Starter
Did a lot of searching and never really got good info, so I decided to post photos of my '68 with an LS1 and T56 out of a 2002 Trans Am mounted with Holley/Hooker engine mounts, trans crossmember and long tube headers.
Measurement taken from center of raised bead just behind the front floor seam on the tunnel.
14.75" from center of "bead" to the front of the shifter hole.
Hole is approximately 4.25" in diameter, I'd use a 4.5" hole saw if it had been available.
Shift lever stub coming out of the transmission is slightly off center of the trans tunnel. Slightly closer to driver's seat.
My car is a factory air car and I had to move the back two passenger side coils due to interference between the coils and the evaporator box. This also required longer plug wires on those 2 coils. I used plug wires off a 5.3 truck on those 2 cylinders.
Hope this helps somebody.
GonHuntin is offline
post #2 of 5 (permalink) Old Jun 1st, 17, 11:42 AM
Ryan
Re: First gen T56 shifter location, Holley mounts
All of your pictures have broken links.
Project: 1968 Camaro 5.3, T56, Z51 brakes, 12 bolt, etc.
ryeguy2006a is offline
post #3 of 5 (permalink) Old Jun 1st, 17, 01:36 PM
Robert
I can see them just fine. Nice write-up.
Vegas69RS is offline
post #4 of 5 (permalink) Old Jul 28th, 17, 05:42 PM
Anne
I wish the pics were viewable.
I can't see them either.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #5 of 5 (permalink) Old Jul 28th, 17, 08:14 PM
Gary
MangeMD's Avatar
Yeah, they are broken for me too.
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
