front springs after LS swap - Team Camaro Tech
 1Likes
  • 1 Post By 69L48Z27
post #1 of 4 (permalink) Old Jun 5th, 17, 12:12 PM Thread Starter
I'm sure this has probably been covered, but I couldn't find it in the last year's posts.
I now have a 2002 LS1 engine in my '68 and, since the all aluminum LS is lighter than my cast iron 327, the front end sits too high. I have Moog 5308 springs in the car and plan to cut a coil and hope it lowers the front enough.......but I thought I'd ask what others have done to see if there is a better option.
While it would be great to have them, I do not want to spend the $$$ for coil over shocks and springs, this is not a track car and never will be.
GonHuntin is offline
post #2 of 4 (permalink) Old Jun 5th, 17, 01:46 PM
Re: front springs after LS swap
1 full coil is approximately 2", so I would guess 1/2 coil is about 1" and so on.
68 Camaro~LSx ~all motor
post #3 of 4 (permalink) Old Jun 5th, 17, 04:51 PM
Garth
I used Hotckiss lowering springs in the 68 we built and it sat the same height as our stock 69. I'm sure anyone's small block lowering springs would work.
6D9 likes this.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #4 of 4 (permalink) Old Dec 11th, 17, 06:31 PM
Apprentice
Jeremy
If you cut your springs it will have to be 1 full coil at time as the spring is manufactured with the ends located in a designated spot. The top side coil spring end mounts in the sub frame and has a locating hole for the spring location. The lower spring will have to match the lower control arm pocket.
I have previously used a small block chev no A/C eibach 2 inch lowering spring with an LS swap which looks about right for the ride height of a stock car. If you are looking to save a few bucks I would cut the stock spring 1 full coil and see how it looks.
Jeremy Camaro is offline
