"MIL" Check Engine light wire - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 2nd, 17, 10:36 AM Thread Starter
DT
Donny
DT's Avatar
I just read in my GMPP wire instructions that the "MIL" Malfunction Indicator Lamp AKA Check Engine Light wire is located next to the DBW pedal/harness. I haven't had a chance to verify this yet. Anyone confirm this ??? I was hoping to get a little wiring done today. Thx.
DT is offline
post #2 of 7 (permalink) Old Jul 2nd, 17, 02:01 PM
Chris
130fe's Avatar
Post Re: "MIL" Check Engine light wire
You are correct, the MIL wire is by the gas pedal. It is a ground (triggered wire). According to the GMPP instructions, you connect it to an light/led. The harness wire goes to the ground side of the light and you will have to put an 12v ignition source on the POS side of it.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #3 of 7 (permalink) Old Jul 2nd, 17, 02:43 PM Thread Starter
DT
Donny
DT's Avatar
Thank you Chris.
DT is offline
post #4 of 7 (permalink) Old Jul 2nd, 17, 09:09 PM
Shawn
This should be in a small wire loom with the 12v ignition power wire for the ECU, wire it like Chris says above and all should be good. IIRC it is a black wire and it will have an indication piece of tape that says MIL on it
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #5 of 7 (permalink) Old Jul 3rd, 17, 04:10 AM Thread Starter
DT
Donny
DT's Avatar
Thank you Shawn.
DT is offline
post #6 of 7 (permalink) Old Jul 3rd, 17, 05:02 AM
Vega$69's Avatar
12V to the LED and the MIL wore from the harness to the ground side.
If you have Dakota Digital gauges you run the mil to the box.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 7 (permalink) Old Jul 3rd, 17, 05:24 AM Thread Starter
DT
Donny
DT's Avatar
Thanks John, My Vintage gauges require a 12V + for the light. I had to use a relay to convert from neg to pos trigger.
DT is offline
