oil pan sensor ? - Team Camaro Tech
 3Likes
  • 1 Post By stugger
  • 1 Post By stugger
  • 1 Post By gphusker
post #1 of 7 (permalink) Old Aug 1st, 17, 01:15 PM Thread Starter
DT
Donny
DT's Avatar
oil pan sensor ?
OK guys, I just looked at the oil pan on my LS3 crate engine and noticed this sensor. The Holley pan has no provision for this. What did you guys do ?? Thx.
DT is offline
post #2 of 7 (permalink) Old Aug 1st, 17, 01:38 PM
Re: oil pan sensor ?
On the corresponding connector,
If sensor is a level sensor, short across the closed contacts indicating to the PCM oil level is good.
If sensor is a temp sensor, boil in a pan of water to a 180-220 and measure resistance, then jumper in a resistor of close to the same value, since there are three terminals, in satisfying the PCM.
post #3 of 7 (permalink) Old Aug 1st, 17, 01:57 PM Thread Starter
DT
Donny
DT's Avatar
Thanks Everett, I think it may just be a low oil level sensor. I have to look if my GMPP harness has a connection for it. I'm guessing it might not even be used.
DT is offline
post #4 of 7 (permalink) Old Aug 1st, 17, 03:04 PM
Shawn
I believe it is a high temperature sensor but fear not, you don't have a plug for this on the GMPP harness so you don't have to worry about having a provision in the Holley pan!
dhutton likes this.
1969 Camaro X44 LSX376 B8, 6 speed T56, Hooker Header Exhaust, Dakota Digital VHX Gauges, Retrosound Model II
Build Thread:
stugger is offline
post #5 of 7 (permalink) Old Aug 1st, 17, 06:18 PM Thread Starter
DT
Donny
DT's Avatar
Thanks Shawn!!
DT is offline
post #6 of 7 (permalink) Old Aug 2nd, 17, 09:40 AM
Shawn
Originally Posted by DT View Post
Thanks Shawn!!
You're welcome sir! Also after doing some research it looks like you were right and it is an oil level sensor, not a temperature sensor.
DT likes this.
Build Thread:
stugger is offline
post #7 of 7 (permalink) Old Aug 2nd, 17, 11:09 AM
Greg
I don't think there is a connector on the harness for it. I could be wrong, but I don't have mine hooked up (if there is a connector) and there are no codes.
DT likes this.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
