LS3 oil - Team Camaro Tech
 3Likes
  • 1 Post By Vega
  • 1 Post By DOUG G
  • 1 Post By 67Rally
post #1 of 7 (permalink) Old Aug 6th, 17, 05:35 AM Thread Starter
DT
Donny
DT's Avatar
LS3 oil
What oil you guys use for a crate LS3? Just the Dexos 5w30 ??
DT is offline
post #2 of 7 (permalink) Old Aug 6th, 17, 05:40 AM
Vega$69's Avatar
Re: LS3 oil
Mobile 1 5/30. Has been used by GM is LS engines since 1997.
That's what I use exclusively.
kcmoney13 likes this.
Vega$69 is offline
post #3 of 7 (permalink) Old Aug 6th, 17, 07:29 AM Thread Starter
DT
Donny
DT's Avatar
Re: LS3 oil
Thanks John. I was just curious if I should use the blend for initial break in. I'm still a ways away from start up, just was going to add oil now after I buttoned up the Holley pan.
DT is offline
post #4 of 7 (permalink) Old Aug 6th, 17, 11:42 AM
Re: LS3 oil
Mobil 1 5/30
DT likes this.
68 Camaro~LSx ~all motor
post #5 of 7 (permalink) Old Aug 6th, 17, 12:14 PM
Brent
67Rally's Avatar
Re: LS3 oil
x3 on Mobil 1 5w30.
Dexos is a standard, not a brand. Mobil 1 is Dexos. But there are a lot of other Dexos approved brands as well. Stick with the good stuff.
DT likes this.
67Rally is offline
post #6 of 7 (permalink) Old Aug 7th, 17, 10:25 AM
TJ
Re: LS3 oil
just broke mine in with mobil 1 5-30 just like when i bought a my 2010 camaro. if it's good enough for a new car, it's good enough for a new engine.
ttwo is offline
post #7 of 7 (permalink) Old Aug 7th, 17, 11:03 AM
Greg
Re: LS3 oil
x5 on Mobil 1 5w-30w. I started mine up did my initial break in procedure which calls for acceleration runs at part throttle to I believe 4k. After I was done doing all that I changed the oil. Changed the oil again at 500 miles and again at 1k. Then again at 2k. Probably overkill changing so much but cheap insurance the way I look at it. I will probably only change once a season now that I feel everything is broke in.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
