LS3 build finally moving along - Team Camaro Tech
 49Likes
post #1 of 154 (permalink) Old Aug 6th, 17, 01:26 PM Thread Starter
DT
Donny
DT's Avatar
OK guys, I'm finally moving forward. I just dropped the LS3 in today. I installed the ECM above the batt tray on the pass fender with a bracket I made, (template from another member on Lateral G). Harness is almost ready to plug in. Fuse box is mounted. Headers are in. Its a slow build, but I'm moving forward now LOL. Thanks to a bunch of guys on here, things are getting done. The wood is keeping the engine from hitting the firewall. Haha. Tranny to be installed later. Here are a couple of pics, nothing fancy.
ID:	189434   Click image for larger version
ID:	189442   Click image for larger version
ID:	189458   Click image for larger version
DT is offline
post #2 of 154 (permalink) Old Aug 6th, 17, 01:52 PM
Brent
67Rally's Avatar
Re: LS3 build finally moving along
Looking Good!
DT likes this.
67Rally is offline
post #3 of 154 (permalink) Old Aug 7th, 17, 10:27 AM
TJ
are you putting in a tremec 6 speed? the hooker kit is awesome. Everything fit like a glove!
DT likes this.
ttwo is offline
post #4 of 154 (permalink) Old Aug 7th, 17, 01:33 PM Thread Starter
DT
Donny
DT's Avatar
TJ, I have the TKO 5 speed. So far the Holley/Hooker kit was seamless.
DT is offline
post #5 of 154 (permalink) Old Aug 7th, 17, 03:25 PM Thread Starter
DT
Donny
DT's Avatar
Solenoid, battery cable, starter trigger wire installed.
zboss86 likes this.
DT is offline
post #6 of 154 (permalink) Old Aug 7th, 17, 03:49 PM
Vega$69's Avatar
Like it. Putting the ECU where you can access it if you have to is a very good idea. The LS7 car I built I mounted it up under the dash and AC evaporator. PIA to get to. Never again.
Mark Stilow mentioned he did the same thing once and only once. I now put them where you did or hide them in plain site with w Dirty Dingo Bracket on the smoothed firewall
zboss86 likes this.
Vega$69 is offline
post #7 of 154 (permalink) Old Aug 7th, 17, 04:39 PM Thread Starter
DT
Donny
DT's Avatar
John, the ECM mount came out great. The bracket mounts to the fender and the radiator support.
DT is offline
post #8 of 154 (permalink) Old Aug 14th, 17, 02:33 PM
Lee
DT,
I've been searching around this, and other, sites looking for information regarding LS swaps with a TKO transmission using the newer Hooker/Holley kits. It looks like we're starting to see a few swaps using the Holley kit with a TKO. I sort of gave up on this route after being told by two different Holley techs that the TKO will/may work with their kit.
So, it looks like your happy with your Holley swap kit, correct? I'm guessing you used their clamshell-mount setup, 302-2 oil pan, headers (which headers did you go with?)? How about the transmission cross-member, did you use one from a TKO kit? Any modifications to the cross-member needed to achieve a decent incline angle?
I apologize for the ton of questions, but I feel this Holley system can be a "no-brainer" under the right conditions.
Thanks,
Lee
Lee N is offline
post #9 of 154 (permalink) Old Aug 14th, 17, 03:54 PM
Peter
Which LS3 did you use? 430, 480, 525? I still have not settled on my choice.
Can you post a link to the bracket template?
Pete
69 Camaro
Owner for 33 years
pwentz3l is online now
post #10 of 154 (permalink) Old Aug 14th, 17, 05:40 PM
TJ
I suggest the 480 as it is better than stock with a somewhat 'cammy' sound yet not so much that you can't idle smoothly. 500 HP is just right!
ttwo is offline
post #11 of 154 (permalink) Old Aug 15th, 17, 02:34 PM Thread Starter
DT
Donny
DT's Avatar
Originally Posted by Lee N View Post
DT,
Thanks,
Lee
Hello Lee. So far the LS 3/495 dropped right in with the Holley swap kit. Headers (Hooker long tube 2276), Motor mounts, everything fit like a glove. As far as the TKO, well right now I'm having issues finding the correct TO bearing. I had to return the LS7 clutch kit as McLeod told me the LS7 clutch kit and their TO bearing will NOT work. The x member I will be using is from Hurst Drivelines. I had the one from my kit (SST Transmissions) but I returned that one for the Hurst Driveline one. I have not mounted the TKO yet, so I can't say what problems I ran into if any. I don't think driveline angle will be a problem.
DT is offline
post #12 of 154 (permalink) Old Aug 15th, 17, 02:37 PM Thread Starter
DT
Donny
DT's Avatar
I have the LS3 480 which they now claim is 495. Which Bracket ?? The ECM ?? If yes, I made my own using a template from a member over at Lateral G. LMK if any pics will help.
DT is offline
post #13 of 154 (permalink) Old Aug 15th, 17, 05:15 PM
Peter
Yes, the bracket. If you could post a link to the template, I would appreciate it.
I'm at a toss up between the 495 and 525. It was always going to be the 525... but some consultants have hinted towards the 480 (495)...
Pete
69 Camaro
Owner for 33 years
post #14 of 154 (permalink) Old Aug 15th, 17, 05:32 PM Thread Starter
DT
Donny
DT's Avatar
Yes, the 480 is a very good platform. I have heard a few negative reviews of the 525 version. Guys were complaining of the cam and street ability. Go figure LOL . I don't have any link for the template. The guy over at Lateral G sent it to me via the US Mail. I have the actual sheet metal template.
DT is offline
post #15 of 154 (permalink) Old Aug 16th, 17, 04:21 AM
Greg
I have the LS3/480 with a 4L70E and it is extremely streetable. Very mild mannered off of idle and has a decent lope to it at idle. Nothing crazy but enough of one to let everyone know you have a cam in it. I don't know a ton about the 525 version but if I were wanting more HP down the road you can toss in a cam from Texas Speed/Brian Tooley and get a nice bump doing nothing else.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
