LS and factory heater core box - Team Camaro Tech
 1Likes
post #1 of 25 (permalink) Old Sep 17th, 17, 08:00 AM Thread Starter
Paul
just bought a LS1 for my 69, in all LS swap pics I've seen everybody has smoothed firewall, does the LS hit the factory heater core box if using factory heater core non AC?
The whiskys gone but I aint leavin
Paul O is offline
post #2 of 25 (permalink) Old Sep 17th, 17, 10:23 AM
Re: LS and factory heater core box
Holley mounts will let it clear. Not sure about the others.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 25 (permalink) Old Sep 17th, 17, 02:16 PM
Mine is 3/4" off the firewall....maybe....but if you used the Dirty Dingo mounts, you could put it where you want as long as you're OK with moving the trans forward too ?...I kept mine in stock location.
68 Camaro~LSx ~all motor
post #4 of 25 (permalink) Old Sep 17th, 17, 04:31 PM
Garth
Holley setup here with big block heater cover. No issues.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #5 of 25 (permalink) Old Sep 17th, 17, 05:21 PM Thread Starter
Paul
is the big block heater cover different than small block?
Paul O is offline
post #6 of 25 (permalink) Old Sep 17th, 17, 05:31 PM
Yep. It is shorter.
post #7 of 25 (permalink) Old Sep 17th, 17, 06:29 PM
Chris
130fe's Avatar
If you need a factory BB outer heater cover, let me know. I have a spare one.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #8 of 25 (permalink) Old Sep 17th, 17, 06:33 PM
Garth
I don't think the cover itself is that different in dimension, difference is heater core outlets. Small block is toward to driver's side of the cover and big block is in the middle.
I,would think the small block routing would be okay, my experience was with the big block cover.
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #9 of 25 (permalink) Old Sep 17th, 17, 06:53 PM
My mistake. You are correct.
post #10 of 25 (permalink) Old Sep 17th, 17, 07:04 PM
Vega$69's Avatar
You need a BBC heater core and cover.
You can also buy jus a core and use a neat kit that adapts the SBC box to work with the BBC cover.
Did it on Rob's 67 LS3 swap and worked great.
You don't even have to pull the cover.
67-69 CAMARO 70 NOVA SMALL BLOCK HEATER BOX COVER CONVERSION TO BIG BLOCK COVER https://www.ebay.com/i/192308281386
Vega$69 is offline
post #11 of 25 (permalink) Old Sep 17th, 17, 07:20 PM
Holley mounts do not require a BB heater core and cover because they place the engine further forward. I would post a pic but I don't have the patience to mess with it. Google it. Images - Holley LS mounts camaro firewall....
post #12 of 25 (permalink) Old Sep 17th, 17, 07:42 PM
Vega$69's Avatar
I believe the Holley kit moves the engine 1 1/2" forward and down perhaps enough the clear the SBC heater core hose connections.
All the cars I've done except Rob's had aftermarket AC.
In his we wanted the engine in the stock location to work with the TKO600 and console he had already installed with his SBC.
Vega$69 is offline
post #13 of 25 (permalink) Old Sep 18th, 17, 02:47 AM
IF you keep the trans in the stock location (using set-back mounts)....the motor is 3/4" or so off the firewall.
I opted to remove 1/2 of my box so I could keep the fan, but loose the heater core (leaked anyway).
post #14 of 25 (permalink) Old Sep 18th, 17, 12:38 PM Thread Starter
Paul
If I use the Holley mounts where will it place my TKO 600 5spd?
Paul O is offline
post #15 of 25 (permalink) Old Sep 18th, 17, 01:51 PM
Send a PM to DT. He has done it.
