Mechanical clutch linkage - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 13 (permalink) Old Oct 6th, 17, 03:50 AM Thread Starter
Do LS swaps have to use hydraulic clutch setups or is it just a lesser of the two evils scenario?
3d cad is offline
post #2 of 13 (permalink) Old Oct 6th, 17, 04:13 AM
Greg
pittpens24's Avatar
Re: Mechanical clutch linkage
Either way - go hydraulic! I was stubborn and went mechanical on my MarkIV and am now regretting it. There is no room for anything, pain in the a$$ to even get in there to adjust it and on top of that, now I need the help of a nuclear scientist to help figure out how to hook up a return spring to the clutch fork. Sounds stupid, but I have no straight shot in my application to connect to anything without rubbing on something else. I have some ideas for the fix, but shouldn't be this hard period. Go hydraulic!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 13 (permalink) Old Oct 6th, 17, 04:33 AM Thread Starter
I am fully in tune with the stubborn component.
3d cad is offline
post #4 of 13 (permalink) Old Oct 6th, 17, 05:20 AM
Vega$69's Avatar
There is no provision the the clutch ball on a LS block. They do make a bracket that bolts on with the bell housing bolts. Depending on where you locate your engine forward and back and up and down you may not line up with the Z bar bracket on the subframe and then you may have to deal with header and clutch linkage interference.
I just put a TKO600 in my SS396 car and went hydraulic to avoid the above potential issues.
DT likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 13 (permalink) Old Oct 6th, 17, 02:05 PM Thread Starter
This could get a little long winded... When I started down this path I decided early that I was gonna build a small block that could mess with the LS cars and after a while decided that was a fools errand. Can you do it? sure. Can you do it in a car that can run a few thousand miles to and from the power tour......maybe. I am after a big inch small block. So I started looking at LS swaps and studying up on the LS motor a bit. I cant leave things alone. Whatever LS I would get would be messed with so for me an iron block is in order and perhaps an aftermarket one because the LS and the SBC do share some deficiencies. It seems that an LS kinda sucks in the fit dept. Stuff is in the way. I don't want an aftermarket subframe. The easy thing to do is drop an automatic in. Nah. I am going to put a TKO 600 in with a shield. From what I read it appears that clutch issues are the #1 pita in finished conversions mechanical or hydraulic. The burr under the saddle that never goes away. So how to get around this? For a while I had it in my mind that Mitchells LS hybrid was the way out of this. LS up top. SBC underneath and out back. Original stuff fits. Lately I decided I was delusional. Then I ran across Dart's LS Next SHP info. It seems that block works out some of the issues underneath but apparently not out back. I haven't found anyone on line that has gone down this path and Dart isn't much help. Dave had me looking real hard at the SB2 but that's such a different animal that I wont go there either. I don't mind making stuff I cant buy. Sometimes I would rather do that just because. Anyway I have to figure this out and somewhat soon. My rear should show up as loose parts this coming week and after I get that in I am going to need to have a block, shield, and tranny sitting here to work onto the subframe and under the car. I would just hate to have to get a LY6 and do something reasonable.
3d cad is offline
post #6 of 13 (permalink) Old Oct 7th, 17, 05:34 AM
DT
Donny
DT's Avatar
Forgive me, but I'm not understanding your logic with respect to the LS deficiencies. Fit ?? My LS dropped right in with a stock subframe and the Holley mounts and oil pan. Headers fit awesome. Thinking about mechanical linkage ??? NO comparison with a hydraulic set-up. I think your mind set is still somewhat Old School and the NEW stuff is somewhat intimidating. (It was to me as well in the beginning) If cost was the issue I could completely see your point. The little incidentals are adding up quickly. Go LS and don't look back. Good Luck.
DT is offline
post #7 of 13 (permalink) Old Oct 7th, 17, 05:50 AM
Vega$69's Avatar
Steve. I don't know what stuff you feel is in the way.
I've done a lot of swaps with both aftermarket and stock subframes. Never had an issue with fitting. Used T56, TKO600 and 4L65E trannys. With and without ac. Power and manual brakes etc.
Only fit issue I ran into was with the heater tubes on a 67 with the stock SBC heater box. Converted it to a BBC box cover solved the issue. All other builds had Vintage Air.
The SBC/LS hybrid is expensive and I don't see what it gives you over the LS except headaches.
Iron blocks are good for going big like a LSX 496 or boosted applications and nitrous. Other then that you can get big reliable power with the aluminum block.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 13 (permalink) Old Oct 7th, 17, 07:06 AM Thread Starter
I want to build a long rod stroker motor. I dont need it. Its not cost effective. Dont be introducing logic here. At the very least ill get a LY6 and stroke it a little bit. Anyway neither sbc or ls factory blocks clear the cranks so if im stuck with aftermarket iron anyway.... as soon as you think stroker the cost game changes at you kinda wind up at the same point regardless of path.
i get the sense from reading here and on other sites that the clutch component of these swaps is the biggest long term pita. Getting a setup that worked reliably with a QuickTime shield was an ongoing effort so yeah, i was looking back at old school. I havent owned a hydraulic clutch car i liked. My friends that had hydraulics in their race cars got rid of them. At the moment i view them as a pain in the *** id rather avoid. Yeah, i could be all wet and that stubborn is playing a part here.
I already converted it to a bb heater John.
3d cad is offline
post #9 of 13 (permalink) Old Oct 7th, 17, 10:37 AM
Vega$69's Avatar
Every new car produced from about 1990 with a manual both domestic and foreign have hydraulic clutches. Obviously they work very well.
I installed one on an LS3 with a Old Lakewood SBC scattershield 3 years ago and it's still performing flawlessly
You can cleareance stock blocks for stroker cranks.
Just sayin.
Vega$69 is offline
post #10 of 13 (permalink) Old Oct 7th, 17, 04:58 PM Thread Starter
Huh, John. You actually used an old lakewood?. I read they were different either with an extra or missing bolt hole but i didnt know the lined up. I have 1 or 2 of those. ....lookin at ebay......
3d cad is offline
post #11 of 13 (permalink) Old Oct 7th, 17, 08:04 PM
Vega$69's Avatar
Yep. I'll look for the pics. I think one at the top.
Same bolt pattern as the GM aluminum SBC and BBC bells.
Vega$69 is offline
post #12 of 13 (permalink) Old Oct 8th, 17, 07:03 AM
Greg
pittpens24's Avatar
You sound like me lol. If you have the will - there is a way.......you just need to find it! Finally found mine with the return spring thinking outside the box. Actually made a bracket that utilized one of the quicktime bell housing bolts and a trip to Tractor Supply for a short spring - works like a champ. Keep in mind that if you do go mechanical, replace as much of the stock rods as possible and replace them with rod ends. Made a huge difference in my dual disc clutch set-up
Moser 9" with 4:11
572 BB - CM Engines
post #13 of 13 (permalink) Old Oct 8th, 17, 05:13 PM
Chris
Yes, like Greg suggests, heim end linkage rods.
https://www.speeddirect.com/index.ph...ucts/rod-links
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
