TKO question - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 8th, 18, 12:54 PM Thread Starter
TKO question
I have no idea at this point if I will put the console back in the car. Console setups for the tremec are offset. Is there any reason why I shouldn't use the offset shifter setup without the console? it has been 45 years since I have driven a Camaro with a shifter in a stock location and I don't remember what it was like. I put a super shifter in it in 72 and that was it until I permanently parked it in 84. I thought that super shifter's position was the best. The Tremec setups wont get close to that, I don't think, even with the offset, but anyway is there a down side to the offset?
thanks
3d cad is offline
post #2 of 9 (permalink) Old Feb 8th, 18, 01:28 PM
Steven
stamatisg1977's Avatar
Re: TKO question
i ran my tko with stock shifter up thru the console and didnt have to modify anything
ID:	204313   Click image for larger version
ID:	204321   Click image for larger version
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 9 (permalink) Old Feb 8th, 18, 02:58 PM
Darin
ilikeike's Avatar
Re: TKO question
Don't the TKO Camaro kits come with the correct shifter ? mine is in the stock location,uses the factory tunnel cut, fits in the factory console with the factory boot.
If you want it in a different location other than factory maybe modify your super shifter to work with the TKO ?
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 9 (permalink) Old Feb 8th, 18, 04:56 PM Thread Starter
Re: TKO question
Im not too concerned with correct with regard to the car. At the moment there is no tunnel hole to match. I would kinda like it to be able to fit in the console should i decide to put it in but am more concerned with it feeling fight than looking right. I am a little curious if the shifter gets weird as you offset it. Theres bound to be some tiller effect to it.
3d cad is offline
post #5 of 9 (permalink) Old Feb 8th, 18, 05:26 PM
Apprentice
Greg
Re: TKO question
Same Here!
gregster1234 is offline
post #6 of 9 (permalink) Old Feb 8th, 18, 06:37 PM Thread Starter
Re: TKO question
Great pic Greg. Thats the straight up setup, not the offset, correct?
3d cad is offline
post #7 of 9 (permalink) Old Mar 3rd, 18, 09:20 PM
Apprentice
Greg
Re: TKO question
Yes that is stock Tremec shifter and Hurst Handle #7436
post #8 of 9 (permalink) Old Mar 4th, 18, 06:23 AM
Vega$69's Avatar
Re: TKO question
Yes but the hole in the shifter console plate is offset to the drivers side. It is not centered on the console.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 9 (permalink) Old Mar 4th, 18, 09:41 AM
Re: TKO question
The handle is bolted on, one could add spacers doe matching plate?
post #10 of 9 (permalink) Old Mar 4th, 18, 09:42 AM
Re: TKO question
The handle is bolted on, one could add spacers matching the plate opening.
