LS3 prime engine ? - Team Camaro Tech
 15Likes
post #1 of 64 (permalink) Old Feb 24th, 18, 05:16 AM Thread Starter
DT
Donny
DT's Avatar
LS3 prime engine ?
What did you guys do to prime your LS engine ?? I have been reading a number of guys purchased pre-lube tanks to prime the engine because they felt the "GM" instructions were not adequate on priming. I mean pre-lube tanks really ???
DT is offline
post #2 of 64 (permalink) Old Feb 24th, 18, 05:52 AM
Re: LS3 prime engine ?
You will get many diverse opinions on this. I donít use a pre-luber but wonít bother sharing my personal method because I know forum experts with more credibility will disagree...
Latest GM instruction now specify use of a pre-luber as far as I know.
Bottom line is make sure you have it primed before you start it.
DT likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 64 (permalink) Old Feb 24th, 18, 07:14 AM
Simon
This is directly from the Chevrolet Performance catalog.
PRIMING THE LS ENGINE
If youíre used to building classic Small-Block and Big-Block engines, youíve probably used an electric drill or similar tool in the distributor hole to drive the oil pump and prime the engine prior to start-up. LS engines donít use distributors, so engine priming must be performed in other ways. First of all, fill the oil pump pickup with oil when assembling the engine. That will ensure a quantity of oil is in the pump when the engine is started for the first time. Also, disconnect either the fuel supply or ignition system when itís time to start the engine and allow the engine to ďroll overĒ for approximately 30 seconds. That allows oil to circulate through the engine without the engine running. Removing spark plugs will allow the engine to prime faster with less load on the bearings. Then, reconnect the fuel or ignition and fire up your LS engine!
slazisme is offline
post #4 of 64 (permalink) Old Feb 24th, 18, 07:21 AM Thread Starter
DT
Donny
DT's Avatar
Thanks Simon, this is the exact GM instructions I am talking about that is NOT adequate as deemed by many.
DT is offline
post #5 of 64 (permalink) Old Feb 24th, 18, 08:00 AM
Ken
The cost of a prelube is not that much. ( check summit) I use on my ls builds as its a little better way to go.( No one argues that pulling the distb and priming is not the best way) that being said ( was in auto parts and machine shop business for many years) many customers that bought engines or had engines built never primed other then cranking ( I don't recommend on a performance motor) and don't have issues. Final thought, I have watched/ been involved in etc many many engines and it can be surprising once in a while how long it can take a engine to pump oil completely through the system hence my preference for priming all my own motors.. Cheers
Sent from my SM-G920R4 using Tapatalk
DT likes this.
partsguy57 is offline
post #6 of 64 (permalink) Old Feb 24th, 18, 08:20 AM
Vega$69's Avatar
This exactly how I've done every LS engine including built LS7, LS3 crate and LSX. I disconnect the ECM and then crank until I see OP on the gauge. Hook up the ECM and start the engine.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 64 (permalink) Old Feb 24th, 18, 09:22 AM
Latest instructions specifying Kent Moore pre-luber here:
http://www.chevrolet.com/content/dam...e-19301326.pdf
DT likes this.
dhutton is offline
post #8 of 64 (permalink) Old Feb 24th, 18, 10:14 AM Thread Starter
DT
Donny
DT's Avatar
Thanks John. I have been reading guys complaining they have not seen any oil pressure on their gauge while cranking using the GM method.
Wow, pricey Don !!!
DT is offline
post #9 of 64 (permalink) Old Feb 24th, 18, 10:20 AM
Wow, pricey Don !!!
Looks very similar to the OTC unit which costs less...
https://www.ebay.com/itm/Engine-Prel...19.m1438.l2649
I canít imagine which pre-luber you use makes any difference. GM always specifies pricey Kent Moore tools.
dhutton is offline
post #10 of 64 (permalink) Old Feb 24th, 18, 10:22 AM Thread Starter
DT
Donny
DT's Avatar
I just looked on Summit's web site, they have a few for much less.
DT is offline
post #11 of 64 (permalink) Old Feb 24th, 18, 10:28 AM
Some of them donít include adaptors so you have to figure out what you need to connect to the LS pressure sender port.
dhutton is offline
post #12 of 64 (permalink) Old Feb 24th, 18, 10:48 AM
Steven
stamatisg1977's Avatar
Quick trip to hardware store for a $1 adapter rather than spending $$ extra for the same thing
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #13 of 64 (permalink) Old Feb 24th, 18, 02:26 PM
Your hardware store carries odd size 16x1.5 mm metic to SAE adaptors for a dollar? Awesome store. You wonít find anything like that around here....
dhutton is offline
post #14 of 64 (permalink) Old Feb 24th, 18, 02:43 PM
Steven
settle down guy just stating how companies price gouge
sorry im not being mathematically correct i should know prices on non common adapters
Tremec TKO 600
post #15 of 64 (permalink) Old Feb 24th, 18, 04:00 PM
Not a dollar but I think this will get the job done:
https://www.summitracing.com/parts/equ-9848
dhutton is offline
