New Holley Mid Mount Accessory Drive - Team Camaro Tech
 10Likes
post #1 of 23 (permalink) Old Mar 8th, 18, 06:57 AM Thread Starter
Vega$69's Avatar
Installed this in the LS3 in my Chevelle a few days ago.
Very nice and compact.
The water pump casting is also the mount for the PS, Alt and Comp. No brackets
wireboy355 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #2 of 23 (permalink) Old Mar 8th, 18, 09:19 AM
Greg
Re: New Holley Mid Mount Accessory Drive
I really like that. I wish they had come out with that a couple years ago. Now if someone would come out with a mount for a 1st gen LS that allows you to have a/c, PS, and a procharger.
frog7151 and Bricks67 like this.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #3 of 23 (permalink) Old Mar 8th, 18, 04:51 PM
Chris
130fe's Avatar
Post Re: New Holley Mid Mount Accessory Drive
I have one in the box going in my car in the next couple of weeks. John, any issues with installation? Looks pretty straight forward. Did the kit come with 4 awg wiring for the alternator?
zboss86 likes this.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #4 of 23 (permalink) Old Mar 8th, 18, 05:21 PM Thread Starter
Vega$69's Avatar
Came with the pigtail for the Alt.
Easy install no issues. The PS pump reservoir return nipple is close to my steering box on the Chevelle ( will work ok). The Chevelle is a front steer so the box is further forward than on a Camaro.
You'll need the correct tools to pull and install the balancer and PS pulley
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 23 (permalink) Old Mar 8th, 18, 08:43 PM
Gary
69Z28-RS's Avatar
John, I really like that as well... If I understand correctly, it's a NEW water pump with all the brackets 'built in'?? or ?? Can you provide Holley PN and cost?
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #6 of 23 (permalink) Old Mar 8th, 18, 09:19 PM Thread Starter
Vega$69's Avatar
Holley 20-185: LS Mid-Mount Complete Accessory Drive Kit | JEGS
I paid a little less 👍
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 23 (permalink) Old Mar 9th, 18, 02:35 AM
Nice set-up for guys running PS, AC, and such.
Compact
68 Camaro~LSx ~all motor
post #8 of 23 (permalink) Old Mar 9th, 18, 03:32 AM
Greg
pittpens24's Avatar
Nice and compact set-up! Would suck if you had a defective water pump out of the box tho.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #9 of 23 (permalink) Old Mar 9th, 18, 05:55 AM Thread Starter
Vega$69's Avatar
The water pump impeller mounts to the casting as a separate part and easy to change.
pittpens24 likes this.
Vega$69 is offline
post #10 of 23 (permalink) Old Mar 9th, 18, 06:08 AM
George
Gbauer's Avatar
I was wondering about that as well.
I think I'd buy a spare rebuild kit to have on hand just in case as this won't be a parts store purchase later.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #11 of 23 (permalink) Old Mar 9th, 18, 07:27 AM
Shad
zboss86's Avatar
that looks nice!
My Mistress rebuild...
zboss86 is offline
post #12 of 23 (permalink) Old Mar 11th, 18, 08:53 AM
Apprentice
Barry
Has anyone used this in a 69 ls3 swap yet? Slickest setup I've run across.
bloverby is offline
post #13 of 23 (permalink) Old Mar 11th, 18, 02:05 PM
Chris
130fe's Avatar
Yes it has been used in a 69. A buddy of mine in Kentucky had his 69 used as a test mule for the system. It fits really well!
Chris
130fe is offline
post #14 of 23 (permalink) Old Mar 11th, 18, 03:28 PM
Apprentice
Barry
Thanks, I'm still planning a swap, was hoping this would work.
bloverby is offline
post #15 of 23 (permalink) Old Mar 11th, 18, 04:54 PM
Brett
Man, That is super nice. Pushes me a little closer to the LS swap edge.
Brett.....
Rockets Up In 2020!
Brettallen59 is online now
