Return line - Team Camaro Tech
 5Likes
  • 1 Post By Sheck44
  • 2 Post By gphusker
  • 1 Post By Vega
  • 1 Post By gphusker
post #1 of 10 (permalink) Old Apr 16th, 18, 03:04 AM Thread Starter
DT
Donny
DT's Avatar
Return line
You guys use a 5/16 return line ? The fitting on the Corvette filter for the return is 5/16. The fittings on my pump that came with the “Tanks” kit is 3/8’s (6AN). Thx
DT is offline
post #2 of 10 (permalink) Old Apr 16th, 18, 04:28 AM
Vega$69's Avatar
Re: Return line
3/8" Use a 5/16 " x -6AN fitting
https://www.summitracing.com/parts/rus-644113
Vega$69 is offline
post #3 of 10 (permalink) Old Apr 16th, 18, 05:24 AM Thread Starter
DT
Donny
DT's Avatar
Oh , I have that fitting. Ok great, I’m all set. Thanks John.
DT is offline
post #4 of 10 (permalink) Old Apr 17th, 18, 05:22 PM
Corey
Re: Return line
Are there any concerns with using a QD 640853 vs 644123? It looks like 644123 uses a metal connection as opposed to the plastic on 640853.
Tanks Inc sells a FPR using QD 640853 & 640863 connectors.
Titan Uranus is offline
post #5 of 10 (permalink) Old Apr 18th, 18, 02:58 AM
Re: Return line
Originally Posted by DT View Post
Oh , I have that fitting. Ok great, Iím all set. Thanks John.
LOL ... Nice one Donny !
DT likes this.
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
post #6 of 10 (permalink) Old Apr 18th, 18, 11:42 AM
Greg
Re: Return line
I haven't personally had any issues but I have read about the 640853's coming loose/off and spraying fuel everywhere. The 644123's are a more reliable design IMO.
dhutton and Titan Uranus like this.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #7 of 10 (permalink) Old Apr 18th, 18, 11:55 AM
Vega$69's Avatar
Re: Return line
The diff is one snaps on and you need a line removal tool to take them off and the other screws on with the U nut.
I have used both and have never experienced any problems with either
Titan Uranus likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 10 (permalink) Old Apr 18th, 18, 12:26 PM
Re: Return line
Originally Posted by Vega$69 View Post
Do you guys use these to go from 3/8" hard fuel line to AN? Would it be the best thing to use to go from factory lines, feed and return, to a fuel pump, regulator, AN lines etc?
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #9 of 10 (permalink) Old Apr 19th, 18, 06:10 AM
Greg
Re: Return line
Those fittings are specifically for going from AN to the connector (which is basically a line with a lip on it) on a fuel rail or even the Corvette fuel filter/regulator that most everyone uses.
To go from the factory hard line to AN you would need a compression fitting like this:
https://www.jegs.com/i/JEGS-Performa...10551/10002/-1
That particular one says max 55psi which could be a problem since the Corvette filter/regulator sets pressure at a constant 58psi. I'm not sure of the reasoning for it only being rated for 55 but I suspect it is because it is a compression fitting and they inherently can only handle so much pressure.
HawkX66 likes this.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #10 of 10 (permalink) Old Apr 19th, 18, 06:44 AM
Vega$69's Avatar
Re: Return line
You would need the steel fitting as the aluminum will not work with the higher pressure
https://www.swagelok.com/en/catalog/...t=SS-600-6-6AN
69 Z28(Sold)
(SOLD)
Vega$69 is offline
