Used LS1 Vette motor - Team Camaro Tech
 5Likes
post #1 of 18 (permalink) Old May 17th, 18, 06:50 AM Thread Starter
Tony
I picked up a used LS1 complete engine from a 2004 Corvette a couple of years ago. It came from a running (but wrecked) car that had 48k miles. Here are my questions:
Since it has been sitting covered in my garage for over 2 years, (no fluids in it and all openings covered),What will I need to do to it to prepare it for the drop into my 1969 Camaro?
Do I need to disassemble the engine for any reason? I was hoping to leave in intact since it has low mileage.
I purchased headers, oil pan and a swap kit so I think I'm covered on mostly everything.
I'm just concerned that it has been sitting for awhile. Also it has that weird chalky white (oxidation?) on it, is this easily removed?
I still need to purchase a stand alone harness and I already have the original PCM..
Thanks for input..
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 18 (permalink) Old May 17th, 18, 07:14 AM
Vega$69's Avatar
Re: Used LS1 Vette motor
Engine should be fine.
You can use the ecm with a new harness but it will need to be re-flashed to delete the VATS and other things that are not used like the rear O2 sensors.
You will also need the throttle pedal unless you got it with the engine. If it was an automatic tranny Corvette and you go manual you may have to get a different ecm
I would go with PSI for the harness and ecm if you need one
I would also do a cam swap. The LS1 is only 350 hp
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 18 (permalink) Old May 17th, 18, 07:26 AM Thread Starter
Tony
Thanks, John!
I got the DBW pedal with the engine. I will be running a 4l60e transmission..
I will look into PSI...
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #4 of 18 (permalink) Old May 17th, 18, 07:31 AM
Vega$69's Avatar
Is the ecm from an automatic Vette?
The 4L60 will fit ok be you may have to clearance the tunnel for the coolant lines and convert to AN fittings
DSE sells a nice bracket for mounting the pedal
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 18 (permalink) Old May 17th, 18, 09:20 AM Thread Starter
Tony
I was told that the ECM and engine are from an automatic..
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #6 of 18 (permalink) Old May 17th, 18, 12:19 PM
Vega$69's Avatar
Should work fine after itís re-flashed
bondora68 likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 18 (permalink) Old May 18th, 18, 06:35 AM
Greg
FWIW I didn't need to clearance my tunnel using my 4l70E and the Holley swap mounts. It was tight but nothing hitting.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #8 of 18 (permalink) Old May 18th, 18, 10:00 AM Thread Starter
Tony
If I do a cam swap, what else will I have to replace?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #9 of 18 (permalink) Old May 18th, 18, 10:01 AM
Vega$69's Avatar
Springs
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 18 (permalink) Old May 18th, 18, 10:03 AM Thread Starter
Tony
Springs
That's it?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #11 of 18 (permalink) Old May 18th, 18, 11:36 AM
Vega$69's Avatar
That's it?
Retainers and locks. Maybe do a trunion upgrade but imho donít really need to.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 18 (permalink) Old May 19th, 18, 07:20 PM
Richard
I just completed this swap in my 1968 camaro. As stated above, I didn't have to make any transmission tunnel modifications with my 4L60e using the Holley swap mounts. It definately is tight up in there, so make sure you get everything tightened down the first time. My LS1 had been sitting for a couple of years also. Vega$69 also advised me to install a cam and new lifters before the swap and I am glad that I did. I also used PSI harness and have 0 complaints.
rebelbayou is offline
post #13 of 18 (permalink) Old May 19th, 18, 08:58 PM Thread Starter
Tony
Can you tell me what cam and lifters you got and where?
Do you have a build thread?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #14 of 18 (permalink) Old May 21st, 18, 05:27 PM
Richard
I do not have a build thread Tony, but tonight I'll dig out my receipts on my cam and lifters and post them for you.
post #15 of 18 (permalink) Old May 21st, 18, 06:24 PM
Rich
You might want to call Cam Motion, they make custom LS cams to your setup and they also offer complete swap kits. I've put 2 of their cams in LS motors and had amazing results.
1967 SS350, Under construction.
H20cooled is offline
