Coolant flow - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 15 (permalink) Old Aug 13th, 18, 02:46 PM Thread Starter
DT
Donny
DT's Avatar
Coolant flow
I filled the upper rad hose into the engine with a gallon of antifreeze hoping I wouldn’t have any coolant flow issues as I’ve seen guys have. Well another bug I need to iron out. What did you guys do? Rad is cold to the touch. Engine around 200 degrees. Thx
DT is offline
post #2 of 15 (permalink) Old Aug 13th, 18, 02:52 PM
Re: Coolant flow
LS crate engines come with a 195 thermostat if I remember right. Did you change it to something lower? It is leveling off at 200 or are you shutting it off at 200?
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 15 (permalink) Old Aug 13th, 18, 03:12 PM
Vega$69's Avatar
Re: Coolant flow
Pull the radiator cap and verify coolant is flowing
Squeeze the radiator hoses to see if firm with engine running.
And Don is correct. Factory T-Stat is 192*.
What are you using for a gauge?
Is this driving on running in the garage?
Are your fans turning on?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 15 (permalink) Old Aug 13th, 18, 04:44 PM
Re: Coolant flow
When filling the cooling system, you need to fill the radiator to about 1" from top, start the car, let it come up to temperature. When the thermostat opens, you might get a over flow with the escaping air (normal), then just add coolant until you're back to about 1" from filler neck.
Sometimes air will get trapped causing hot spots/overheating issues. Raising the front of the car helps most of the time to "burp" the air.
68 Camaro~LSx ~all motor
post #5 of 15 (permalink) Old Aug 13th, 18, 04:44 PM Thread Starter
DT
Donny
DT's Avatar
Stock thermostat, running in garage. I turned it off at 200. Thx guys.
DT is offline
post #6 of 15 (permalink) Old Aug 13th, 18, 04:46 PM Thread Starter
DT
Donny
DT's Avatar
Rad cold to touch. Fans never came on.
DT is offline
post #7 of 15 (permalink) Old Aug 13th, 18, 05:08 PM
Vega$69's Avatar
Re: Coolant flow
Then it's not flowing coolant yet. Coolant is not reaching the temp sensor yet ot the t-stat
After shut off for a while start it again. When temps come up pump the hoses with your hand. Squeezing bottom hose like a dozen times, then the top hose.
Works every time for me.
You said you added a gallaon through the top hose.
How much did you put into the radiator?
dhutton likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 15 (permalink) Old Aug 14th, 18, 06:38 AM Thread Starter
DT
Donny
DT's Avatar
I added another gallon to radiator. Thx John
DT is offline
post #9 of 15 (permalink) Old Aug 14th, 18, 07:33 AM
Greg
Re: Coolant flow
Make sure you have your heater turned on. Flowing water through the heater core helped me get the air bubbles out too.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #10 of 15 (permalink) Old Aug 14th, 18, 09:20 AM
Re: Coolant flow
I donít think that is enough. Fill it until you cover the radiator core tubes.
dhutton is offline
post #11 of 15 (permalink) Old Aug 14th, 18, 01:41 PM Thread Starter
DT
Donny
DT's Avatar
Thx Don, yeah it’s full.
DT is offline
post #12 of 15 (permalink) Old Aug 14th, 18, 03:15 PM
Re: Coolant flow
Thx Don, yeah itís full.
Pretty sure that I used more than 2 gallons. It will take more when the thermostat opens. Keep the cap off and let it come up to temperature. Then squeeze the hoses as John said.
dhutton is offline
post #13 of 15 (permalink) Old Aug 14th, 18, 03:45 PM
Vega$69's Avatar
Re: Coolant flow
I find squeezing with the cap on helps force the air. If cap off the coolant comes out the top.
I squeeze a bunch then take the cap off to check for flow and coolant level.
Vega$69 is offline
post #14 of 15 (permalink) Old Aug 14th, 18, 04:28 PM Thread Starter
DT
Donny
DT's Avatar
Thx guys.
DT is offline
post #15 of 15 (permalink) Old Aug 18th, 18, 12:14 PM Thread Starter
DT
Donny
DT's Avatar
Re: Coolant flow
Thanks everyone for the help. Squeezing the lower hose seemed to do the trick and I also added some more antifreeze from the upper hose. I have coolant flow now and all the air is out.
DT is offline
