LS conversion....need upper rad hose, passenger side. - Team Camaro Tech
 1Likes
  • 1 Post By dhutton
post #1 of 12 (permalink) Old Aug 18th, 18, 08:29 AM Thread Starter
Simon
Calling on resident LS guru's to help out......John, Don or someone else. Need a number on a upper rad hose Dayco, Gates, Napa, etc. that goes to passenger side inlet, needs to be 1.5" both ends. Pic shows basic shape.
Any help would be appreciated, tks.
slazisme is offline
post #2 of 12 (permalink) Old Aug 18th, 18, 08:54 AM
Robert
Re: LS conversion....need upper rad hose, passenger side.
For the upper hose, the upper hose from a 1995 Mitsubishi Eclipse turbo AWD is almost a perfect fit.
I got this from Entropy radiator website (copy/paste). Its what I got and fit perfectly.
Vegas69RS is offline
post #3 of 12 (permalink) Old Aug 18th, 18, 09:27 AM
Beth
Thanks; that looks like what I need too !
Robert,
I looked up that hose and it's 1-5/16" ID.
We need 1-1/2" ID ?
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 12 (permalink) Old Aug 18th, 18, 12:09 PM
DT
Donny
DT's Avatar
That upper Mitsubishi hose did NOT work for me using an Entropy rad. I used the hose Don recommended. I think it was from a Lincoln. I will see if I can find the #.
UPDATE: DAYCO E72126.
DT is offline
post #5 of 12 (permalink) Old Aug 19th, 18, 06:40 AM Thread Starter
Simon
Thanks for all the suggestions.
Donny after I looked up the hose specs you suggested it says the hose ends are 1.25", I know that the the fit should be snug but is stretching a hose that much on a 1.5" rad inlet acceptable? Could you post a decent pic showing the hose installed, even at the ends, tks.
UPDATE: DAYCO E72126.[/QUOTE]
slazisme is offline
post #6 of 12 (permalink) Old Aug 19th, 18, 06:54 AM
[/QUOTE]
Upper hose is 1.25 ID and lower hose is 1.5 for the LS.
Water pump determines which hose will work. What water pump and accessories are you using?
DT likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #7 of 12 (permalink) Old Aug 19th, 18, 07:10 AM Thread Starter
Simon
F body LS1 accessory drive with newer style ls3 thermostat housing.
https://www.rockauto.com/en/moreinfo...=1490544&jsn=4
Rad inlets are both 1.5.
slazisme is offline
post #8 of 12 (permalink) Old Aug 19th, 18, 07:13 AM Thread Starter
Simon
Don I have to head out to a family function, I'll check in with you later on tonight, tks.
slazisme is offline
post #9 of 12 (permalink) Old Aug 19th, 18, 10:20 AM
The Dayco hose is for LS3 crate engines. I think you will likely need that Mitsubishi hose for 4th gen F body accessories.
dhutton is offline
post #10 of 12 (permalink) Old Aug 19th, 18, 11:14 AM
Chris
130fe's Avatar
Post Re: LS conversion....need upper rad hose, passenger side.
I used a 22358 hose, you will only use half of the hose.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #11 of 12 (permalink) Old Aug 20th, 18, 08:48 AM Thread Starter
Simon
Guys, thanks again for the responses.
Don, I can't use the F body hoses because the factory rad inlets are 1.25" and I need 1.5".
I erred in requesting both ends needing to be 1.5", actually I need one end at 1.25" and the other at 1.5"
With the help of Dayco's website:
Online Catalog
On the left hand side is has a heading......dimensional lookup where I plugged in some dimensions and came up with 72341 that I'll try.
slazisme is offline
post #12 of 12 (permalink) Old Aug 20th, 18, 09:41 AM
Vega$69's Avatar
Bend up a coat hanger and take it to the part store to match up a hose. You may end up using only part of the hose you find
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
