69 Camaro l99 with 6l80e swap beginning stage - Team Camaro Tech
 4Likes
post #1 of 28 (permalink) Old Aug 25th, 18, 07:52 PM Thread Starter
E
So finally i started on my LS swap ........ i got an L99 w/ 6l80e out of a 2012 Camaro with approx 66k miles(thats what i was told) so i finally had some time to begin the first stages of the swap. This thread will mainly be my experience of actually ONLY putting the engine and trans in the car and the modifications i need to make it all fit. Ive heard and read of the floor cutting/modification but i want to see and test if there are any other ways to make it work prior to any cutting this is gonna take some time but ill see..... now i wont be doing the wiring yet or mods being that i am on a budget and have another project to tackle but i hope some people find it helpful and maybe i can learn something from someone else. I am not a professional mechanic nor a fabricator but i know my way around a car.
Now to what i have and have purchased and installed, i have a 1969 camaro w/ 383sbc/350trans, rear end is an eaton posi with 3.73 gears and 30 spline moser axles w/ caltrac split leaf and traction bars. c6 corvette disk brakes all around, qa1 adjutable coil over shock at front a couple more things but this covers a lot.
Projections--- i just want it to haul a** LOL but be reliable, nothing major. More than likely afm/dod delete stage 1 cam kit by GPI with trunnion upgrade and minor bolts ons.
What i have so far i purchased the complete bracket kit to make the swap from holley/hooker, meaning motor mounts and oil pan, i am planning on fabricating my own trans crossmember, i have not purchased the brackets to relocate the alternator or compressor but i REALLY liked the brackets from LSBRACKETS.com not sure if anyone has used them they seem simpler and you can save some money which is what i am trying to do. Some feed back would be nice.
What i have done so far is removed the 383sbc and 350 trans i removed the complete front end of the car for easier access to work all around, i have switched out the oil pan and modified the engine pan tray, i have removed the alternator and ac compressor for access and for installing the engine for clearance.
Issues i have encountered and what i need to buy so far----
1- i removed the oil cooler which i no longer will be using but there is big hose on the side off the block connected to the cooler looks like i need a plug for i wasnt aware of this. Located plug via summit after reading another thread part #12561663. You have to install the plug prior to installing the holley motor mount bracket.
2- Oil pan sensor i noticed the holley pan does not have the hole for the sensor not sure what everyone has done about this or if its ok to cancel this sensor out---- need some advise on this.
3- The positive battery cable my engine has a metal cover around it with some loom i made the mounting hole a bit large to try to reuse it i only used one mounting tab i guess will see if it works. Not sure what else everyone has done. Like i said trying to save money where i can.
Addtl questions i have has anyone reused the 2012 camaro radiator i measured it and it looks like a very tight fit i was thinking of reusing it but of course fabricating some brackets to mount it.
I hope other people chime in, I am not a pro at fabricating or mechanical work but have some knowledge so please bare with me.
H20cooled and wireboy355 like this.
elaml123 is offline
post #2 of 28 (permalink) Old Aug 25th, 18, 08:04 PM Thread Starter
E
Re: 69 Camaro l99 with 6l80e swap beginning stage
I tried uploading pics not sure what the deal is.
elaml123 is offline
post #3 of 28 (permalink) Old Aug 26th, 18, 03:49 AM
Oil pan sensor is not needed.
Easiest way to post pics is get a paid membership to the forum. Otherwise you will need to embed links from a photo hosting site.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 28 (permalink) Old Aug 27th, 18, 01:42 PM Thread Starter
E
Thanks for the response ill see if i can post up pics at another site. I will delete the oil sensor then. Quick question on the oil sensor will that bring up a check engine light?
elaml123 is offline
post #5 of 28 (permalink) Old Aug 27th, 18, 01:46 PM
Vega$69's Avatar
Oil sensor in the pan is for oil levels it is not used with any aftermarket swap harnesses that I am aware of it will not bring up a check engine light.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 28 (permalink) Old Sep 2nd, 18, 03:18 PM Thread Starter
E
Alright so today i was able to put the engine and trans in i had to remove the alternator exhaust manifolds and ac compressor to be able to make the engine and trans fit along with removing the wiper motor from the car in order to have proper access.
Issues i have expereinced so far:
1- i purchased the oil cooler plug but after installing it i noticed the allen head plug is HUGE i did not have that socket size so i used an actual BOLT head to tighten it inot the block.
2- Several components needed be removed from engine for easier installation.
3- The directions for the Hooker/Holley motor mounts bushings do not read with direction the guide pins need to be either up or down facing inward or outward towards the engine(wish i can post pics)
It took a bit of time to finesse the engine and trans in but overall it went in the Holley/hooker mounts, I DID NOT modify nor CUT the floor i do not have a crossmber installed yet, what i place 4 pieces of 2x4's underneath the trans to simulate the trans cross-member overall i see an approx 1/4 inch gap around between the trans tunnel and trans itself i still need to properly angle the trans to make sure i have a proper pinion angle. The rear end is a 1970 nova 8.5 10 bolt with original perches i have a 1inch drop on the rear and qa1 adjustable coil over shocks at front, i need to buy angle finder ive never done this so hopefully you guys can help me on this:
Where do i start on the trans of course i know have to lift it but how far and whats the correct angle????
My car is a bit lowered i did seem some minor areas that may be affected if i lift higher than 4 pieces of 2x4's but notihing major where i need to cut the floor, some minor hammmering can make it fit.
I will see if LS1 tech lets me post pics for some odd reason i tried posting last week but my thread did not go up with images.
elaml123 is offline
post #7 of 28 (permalink) Old Sep 2nd, 18, 03:37 PM Thread Starter
E
So i finally got some pics up here is the first set here is the link:
Library Slideshow by elaml123 | Photobucket
patman2 likes this.
elaml123 is offline
post #8 of 28 (permalink) Old Sep 2nd, 18, 03:57 PM Thread Starter
E
So here is another issue NOT related to the install:
What does the sensor behind the intake do and/or what is it for, i will need to replace it? It was broken when bought it.
Hope i get some thought on the pinion/trans angle as i am hoping to maybe get this done next week. Ohhh a few more details as i stated before i want to save money where i can on this swap the battery cable leading the starter you need to remove the metal base that goes underneath the oil pan it will not work on the stock frame it gets in way.
The trans cooler lines so far fit and did not hit the subframe when i turned the steering wheel i did notice a tire rod hit one of the line i wedgeda 2x4 between the line and tie rod and had my dad turn the steering wheel to create a small bend on the line for it to clear the tie rod it worked but ill work out the detail later. SOOO far i have approx 1inch away from the firewall and 1/4 inch between trans and trans tunnel pending trans angle.
elaml123 is offline
post #9 of 28 (permalink) Old Sep 2nd, 18, 04:04 PM Thread Starter
E
Let me know if you guys have any issues with viewing the images.
elaml123 is offline
post #10 of 28 (permalink) Old Sep 2nd, 18, 05:36 PM
Sensor behind intake is the oil pressure sender. Your gauges will likely use a different sender.
post #11 of 28 (permalink) Old Sep 2nd, 18, 05:52 PM
Vega$69's Avatar
And map sensor
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 28 (permalink) Old Sep 2nd, 18, 05:53 PM
DT
Donny
DT's Avatar
Holley recommends 3.0/3.5 driveline angle. Check their website for correct x member.
DT is online now
post #13 of 28 (permalink) Old Sep 2nd, 18, 08:17 PM Thread Starter
E
Originally Posted by Vega$69 View Post
And map sensor
I thought speartech lets you reuse the same map sensor?
elaml123 is offline
post #14 of 28 (permalink) Old Sep 2nd, 18, 08:19 PM Thread Starter
E
Ill check it out thanks do you know if this is positive or negative but the main question is how do i go about and checking for angle i dont have the driveshaft yet.
elaml123 is offline
post #15 of 28 (permalink) Old Sep 3rd, 18, 03:47 AM
Yes they do.
