Header Clearance - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 8th, 18, 07:47 AM Thread Starter
Apprentice
Derrick
Header Clearance
I installed a 6.0L into my 69 Camaro and my driver side header hits the top of the power steering gearbox. I am using dirty dingo Double D adapter plates along with Dynatech 715-31425 headers. I know a lot of people swap out the ps gearbox for some type of quick ratio version. Does anybody know if one of these is smaller and may allow my headers to work? I am also interested in other options that I may have. I really don't want to change the adapter plates since the engine is already in the car. If going with another set of headers is my only option I can look into that as well. Thanks in advance.
weasle is offline
post #2 of 3 (permalink) Old Sep 8th, 18, 09:04 AM
Beth
Re: Header Clearance
I'm using 1-3/4" Holley-Hooker headers with 2-1/2" collectors and they have 1/2" clearance all around the ps box.
The motor mounts are also Holley.
Are your adapter plates adjustable ? Would moving the engine 1/4" or 3/8" solve your problem ? Just redrill the adapter plate mounting holes.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 3 (permalink) Old Sep 8th, 18, 04:31 PM Thread Starter
Apprentice
Derrick
Mine are only adjustable forward and backwards but not really up and down. I believe moving the engine up would help but that may cause other issues plus I don't want to remove the engine. I would probably go with a different set of headers before I did that. I was hoping that a new PS gearbox would work because that would resolve multiple issues.
weasle is offline
