69 camaro ls conversion - Team Camaro Tech
 16Likes
post #1 of 23 (permalink) Old Sep 10th, 18, 02:30 PM Thread Starter
Probationer
First time on forum and many questions.
I have a 69 Camaro SB with factory console 4sp. I want to install LS power and would like a 5 or 6 speed trans. I do not want any floor pan tunnel mods. I am at the reassembly stage and basically need a parts list. I have a SB non a/c heater core and box. Do I need a BB core and cover? I would appreciate input for all of the following.......
Motor and trans mounts that will locate the shifter in factory console.
Trans 5 or 6sp.
power steering gear box for proper clearance.
Header or factory manifold
belt drive system..Alt,pwst
Radiator...
I know with there are adjustments that will need to be made but I am looking for the least amount of cutting and grinding as possible as most of that work is complete.
Thanks..
cindyscam is offline
post #2 of 23 (permalink) Old Sep 10th, 18, 03:15 PM
Re: 69 camaro ls conversion
Go with the Holley system. Mounts, accessory drive, headers, cross member all designed to work together. You can use sb heater core and cover
130fe and H20cooled like this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 23 (permalink) Old Sep 10th, 18, 03:56 PM
Vega$69's Avatar
The SBC Heater core will be tight
You can buy a conversion kit to use a SBC cover with a BBC core
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 23 (permalink) Old Sep 10th, 18, 04:47 PM
Tight with Holley mounts?
post #5 of 23 (permalink) Old Sep 10th, 18, 05:30 PM
Vega$69's Avatar
I think even with the Holley mount the SBC heater tube will be tight to the head.
I have not tried because most I do have Vintage Air.
Did a 67 without VA and did change the heater core to BBC. Did not use the Holley mounts though. I used a bbc heater core and a kit that works with the SBC box and you donít have to pull the box to covert
Maybe somebody here has tried SBC box with the Holley swap?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #6 of 23 (permalink) Old Sep 10th, 18, 05:49 PM
Holley specifically states that their system works with factory heat and air conditioning.
post #7 of 23 (permalink) Old Sep 10th, 18, 05:59 PM
DT
Donny
DT's Avatar
Def go with the Holley set up. One word of caution though, I don’t think the Tko shifter will be in the same position as stock 4 speed location.
DT is offline
post #8 of 23 (permalink) Old Sep 10th, 18, 06:23 PM
Originally Posted by DT View Post
Def go with the Holley set up. One word of caution though, I donít think the Tko shifter will be in the same position as stock 4 speed location.
Does Holley have a TKO 5 Speed crossmember? I thought they only supported the Tremec six speed.
post #9 of 23 (permalink) Old Sep 10th, 18, 07:33 PM
Vega$69's Avatar
I used the crossmember from SST for my TKO600 in my last 69. My others were aftermarket subs.
Fit TKO600 fit the console. The T56 will need an offset shifter
H20cooled likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 23 (permalink) Old Sep 11th, 18, 03:17 AM
Does the header collector line up with the exhaust notch in the crossmember? Iíve seen one case where it was not even close.
DT likes this.
post #11 of 23 (permalink) Old Sep 11th, 18, 04:12 AM
Vega$69's Avatar
Mine lined up. May depend on the Headers used. There was a thread a while back that crossmembers and exhaust was discussed.
DT likes this.
Vega$69 is offline
post #12 of 23 (permalink) Old Sep 11th, 18, 04:54 AM
It does depend on the headers used. This is precisely why I recommended using the entire Holley system. Everything works together with no fit issues etc. Once you deviate from the system you are on your own when issues arise.
DT likes this.
post #13 of 23 (permalink) Old Sep 11th, 18, 04:56 AM
Peter
I just installed an LS3 and Tremec 6 speed. I used Holley motor mounts, Holley Blackheart long tube headers, and the Holley Crossmember. I have a new PS gear box from Detroit speed. I did convert to Vintage Air with their front runner kit. Everything fit great and install was very easy. One thing to be aware of, that Holley does address, is that if you have a stock subframe, the headers are different than if you use a DS subframe. I installed a DS quadralink, so I have to make some modifications to their header back system to make it work. Minor, but not out of the box fit.
ID:	221327   Click image for larger version
ID:	221329   Click image for larger version
ckaram, H20cooled and 350sshugger like this.
Pete
69 Camaro
Owner for 33 years
pwentz3l is online now
post #14 of 23 (permalink) Old Sep 11th, 18, 04:21 PM
DT
Donny
DT's Avatar
They do not. I used the Hurst Driveline x member. Header/collector issues with this x member. I originally had the SST x member and returned it because a member on here had issues with interference. After having both the SST and Hurst x members, I would say stay with the SST one if using a TKO 5 speed.
DT is offline
post #15 of 23 (permalink) Old Sep 11th, 18, 04:26 PM
DT
Donny
DT's Avatar
Holley mounts fit original 4 speed hole??
DT is offline
