69 camaro budget fuel tank - Team Camaro Tech
 4Likes
post #1 of 19 (permalink) Old Nov 16th, 18, 03:39 PM Thread Starter
E
Just wondering if there any cheap reliable options for a fuel tank im doing an l99/6l80e swap and i bumped into a post from a guy who did a 1994 caprice fuel tank swap on his first gen he swapped the pump for a walbro 255 just wondering if this would be a a good swap let me know thanks.
elaml123 is offline
post #2 of 19 (permalink) Old Nov 19th, 18, 03:29 AM
Re: 69 camaro budget fuel tank
Tanks Inc. hands down ... don't even bother wasting your time and $$$
Inexpensive, fits perfect and works 1000% perfectly
Cheers
DT likes this.
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
post #3 of 19 (permalink) Old Nov 19th, 18, 07:49 AM
Steven
stamatisg1977's Avatar
X2!
DT likes this.
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #4 of 19 (permalink) Old Nov 19th, 18, 10:34 AM
Greg
x3
DT likes this.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #5 of 19 (permalink) Old Nov 19th, 18, 10:40 PM Thread Starter
E
I guess i got a few more days to think about it its just spending 500 bucks on a tank when i can spend approx 30 bucks plus the walbro pump is really a big incentive.
elaml123 is offline
post #6 of 19 (permalink) Old Nov 20th, 18, 02:46 AM
??? .... E, $500 gets you almost everything you need for your entire fuel system
Also consider this E, your building a 69' Camaro ... these are always a valuable commodity 'IF' you do them right. This doest mean you have to make it a $100k pro touring car, BUT If you start mashing parts together from different vehicles the value of your car will drop like a stone ... just something to consider
Cheers
Sheck44 is offline
post #7 of 19 (permalink) Old Nov 20th, 18, 05:25 AM
Ed
Holley Stainless Steel Tanks work awesome!!!
ZEN357 is offline
post #8 of 19 (permalink) Old Nov 20th, 18, 09:18 AM
Greg
I can promise you that you will almost always 100% regret going cheap or cutting corners in the end. Every single time I did I ended up doing it over again later.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #9 of 19 (permalink) Old Nov 20th, 18, 03:29 PM
Darin
ilikeike's Avatar
I'd like to see a picture of how well that fit under the car.
I know people do LS swaps on the "cheap" with junkyard pull out drive trains, But I thought the Tanks Inc. setup was still getting off cheap when doing an LS swap.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #10 of 19 (permalink) Old Nov 20th, 18, 03:59 PM
Probationer
Alex
Rockauto sells the Spectra GM32BFI tank for $281 and that includes the fuel pump. Did a 69 LS1 swap last year and it's worked fine for over a year now. If you would feel more comfortable, you can swap the fuel pump for a better version but so far I've had zero issues with it.
Alex
HawkX66 likes this.
CapSS92 is offline
post #11 of 19 (permalink) Old Nov 20th, 18, 11:44 PM
You could just buy the external fuel pump kit I’m selling in the classifieds and drill a return in your sending unit and call it good.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #12 of 19 (permalink) Old Nov 21st, 18, 03:38 AM
Vega$69's Avatar
Where are you getting a tank that fits your car for $30?
How is the Walbro pump installed in the $30 tank?
Just drilling a hole in your stock sending unit doesnít work as the return fuel squirting into the tank wil aerate the fuel in the tank. The return line should extend to the bottom of the tank.
You can use an external pump and bypass regulator along with a dual line sending unit.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #13 of 19 (permalink) Old Nov 21st, 18, 05:07 AM
Just because their 'inexpensive' doesn't mean that they are cheap ... remember its simply only a gas tank, guys that spend $1000's on a Stainless tank do so unnecessarily. I'm sure John will comment, we've sold BIG dollar Camaro's with Tanks Inc. systems and trust me 99.9% of buyers couldn't care less
Cheers
Sheck44 is offline
post #14 of 19 (permalink) Old Nov 21st, 18, 06:22 AM
Darin
ilikeike's Avatar
Cheers
I use a Tanks Inc.
My point was that I thought it was the best easiest and reliable way to go inexpensively,and it fits well.
I try to picture installing an LS inexpensively and not including Tanks inc in the inexpensive category for a project like that.
If a 94 Caprice tank works for $30 awesome!, I'd like to see the pictures.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #15 of 19 (permalink) Old Nov 21st, 18, 06:49 AM
I paid ~$230 for a Spectra GM32BFI tank when I installed the Gen 6 454 in my 69 that doesn't have a provision for a mechanical fuel pump. It works and looks excellent. It's $281 at Rock Auto right now.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
