LS3 controller - Team Camaro Tech
 5Likes
  • 2 Post By Vega
  • 2 Post By Vega
  • 1 Post By MCB
post #1 of 10 (permalink) Old Mar 2nd, 19, 02:37 PM Thread Starter
Steven
stamatisg1977's Avatar
LS3 controller
Hey guys i have been spending the better part of my evening finding ways to save money.
So i decided to look up the individual parts that make up the LS3 controller
I have sourced each part minus the acc pedal(i have that already)
Can someone look over what i have found to make sure it is a wise decision?
LS3 controller kit msrp $1330-$1500
Individual parts lookup $849.92
I looked these up for a 2015 camaro SS
Thanks guys as always !
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 10 (permalink) Old Mar 2nd, 19, 03:26 PM
Vega$69's Avatar
Re: LS3 controller
The harness is a replacement harness for a new Camaro. I donít believe it has the fuse box and relays that come with the GMPP harness. I also doubt it comes with the relays for the fuel pump and ignition or designed with control. Missing would also be the wiring for the tach, speedo OP and Temp gauges.
It is not a Stand Alone harness. Also a good chance the harness runs for the ECU connector are lot long enough to reach wherever the ECU will be mounted. May not has lead for VSS connection to tranny.
The GMPP harness also has an addition bulkhead connector that is very useful when doing LS swap. Canít tell if it has the plug for the pedal as these connections may be interlaced with other wiring harnesses.
Buy the time you Modify the harness to add the things you need it probably wonít be worth the time and effort.
You may be able to buy a GMPP harness without the peak and ECU. Used ECUs can be bought for $100-150 easy.
You can also buy a harness from a company like PSI
130fe and stamatisg1977 like this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 10 (permalink) Old Mar 2nd, 19, 03:31 PM Thread Starter
Steven
Re: LS3 controller
THANKS jOHN NOW IT MAKES SENSE THAT ITS ONLY $180! LOL
Tremec TKO 600
post #4 of 10 (permalink) Old Mar 2nd, 19, 03:32 PM Thread Starter
Steven
Re: LS3 controller
I may just get the PSI LS3 controller
Tremec TKO 600
post #5 of 10 (permalink) Old Mar 2nd, 19, 03:35 PM
Vega$69's Avatar
Re: LS3 controller
For a crate engine I like GMPP because you donít need tuning which costs 4-600
For a built engine like the LS7 I did I like PSI. Comes with a base tune and I have to tune anyway
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #6 of 10 (permalink) Old Mar 2nd, 19, 04:25 PM Thread Starter
Steven
Re: LS3 controller
im changing the cam so i'll need tuning anyways
i also looked at speartech, thats waay out of my price range $1500 just for a harness no ecm or sensors
Tremec TKO 600
post #7 of 10 (permalink) Old Mar 2nd, 19, 05:44 PM
Vega$69's Avatar
Re: LS3 controller
Iíve been happy with Jon at PSI. Never used Speartech however I believe they are pretty good. I tend to stick with what I know works. PSI 2 times and GMPP with crates 6 or 7 builds
130fe and DT like this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 10 (permalink) Old Apr 25th, 19, 11:15 AM
MCB
MCB Parts
Re: LS3 controller
We sell PSI most commonly. We typically do their PCM as well. It is only $50 more than them flashing yours and you will spend almost that much in shipping it both ways.
We offer a good discount on their kits and free ship them as well.
We also offer the FiTech kit which many auto trans guys run due to the VERY good cost on the whole setup!
Feel free to contact me for details and prices on any setup.
MCB
stamatisg1977 likes this.
MCB is offline
post #9 of 10 (permalink) Old Apr 25th, 19, 06:29 PM
Chris
130fe's Avatar
Re: LS3 controller
Another option now is the Holley TerminatorX (with and without trans control) that just came out.
https://www.holley.com/products/fuel.../terminator_x/
Of course give Matt and Kim a call at MCB when you are ready to order!
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #10 of 10 (permalink) Old Apr 26th, 19, 09:00 AM
MCB
MCB Parts
Re: LS3 controller
YES! We have sold a few so far. Most are talking with Holley to ensure they are getting the right pieces and sending us their list. We beat all the big box stores and free ship 99.9% of it as well!
MCB is offline
Which LS3 Supercharger would you recommend ttwo Engine 9 Jan 20th, 19 10:51 AM
LS3 ? or SBC bwarren LSx Swap 126 Sep 14th, 18 06:43 PM
LS3 / Maggie Clearance stinger67 LSx Swap 6 Apr 11th, 18 06:23 AM
LS3 intake manifold shootout dhutton LSx Swap 3 Mar 6th, 18 10:20 AM
Holley Acc Drive #20-137 question (LS3) DT LSx Swap 3 Nov 23rd, 17 03:57 PM
