LS Swap,Gas gauge seems screwy LOL - Team Camaro Tech
 1Likes
  • 1 Post By 69-Pace
post #1 of 3 (permalink) Old Mar 30th, 19, 11:12 AM Thread Starter
DT
Donny
DT's Avatar
OK guys, went for a 15 mile test run today with the car. I noticed the gas gauge seems to be erratic. I put in 7 gallons of gas and it read 1/2. Didn't think much of it. As I was driving it read FULL. 5 minutes later back to 1/2. I'm using the Classic Instruments fuel sender with the Correct Ohms etc for the gauge. This is with a NON vented cap. Any ideas ??
DT is offline
post #2 of 3 (permalink) Old Mar 30th, 19, 11:22 AM
69-Pace's Avatar
Exclamation Re: LS Swap,Gas gauge seems screwy LOL
Sounds like you are loosing your in tank sender ground. You drive and all of a sudden you are seeing it read past full?
Check the sender ground on the passenger side rear tank strap location. It may need a star washer to make good contact.
DT likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 3 (permalink) Old Mar 31st, 19, 04:30 AM Thread Starter
DT
Donny
DT's Avatar
Checked ground, all was tight and secure. Good contact too. I should also mention I'm using Vintage USA gauges. Hmmm.
DT is offline
NEW - Dakota Digital RTX Series Gauge Systems - MUST SEE! MCB Sponsors 2 Dec 9th, 19 01:01 PM
An Evolving Problem CityguyUSA Engine 10 Dec 31st, 18 07:52 AM
69 Camaro Center Fuel gauge not accurate travisch Electrical & Wiring 0 Sep 11th, 18 03:26 PM
Horn Relay location? Larry Madsen Restoration Corner 17 Jan 5th, 18 07:53 PM
Fuel Gauge Issue Brettallen59 Electrical & Wiring 25 Dec 7th, 17 09:33 PM
