Holley Accessory Drive Kit - Team Camaro Tech
 4Likes
post #1 of 18 (permalink) Old Apr 11th, 19, 02:49 PM Thread Starter
Bobby
Purchasing a brand new LS3 from GM, which accessory drive installation kit will I need?
21-1, 21-2, or 21-3?
Car is a 68 Camaro.
https://www.holley.com/products/acce...s/parts/20-138
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 18 (permalink) Old Apr 11th, 19, 03:24 PM
Eric
Re: Holley Accessory Drive Kit
I have the Holley engine mounts and for aesthetic reasons I tried to go with the Holley drive type that places the alternator on the bottom and PS pump up top. I was surprised to find out I did not have the clearance I needed with either a large frame or small frame alternator. I called Holley to confirm my findings and they told me that all cars are different....
So... I ordered the Dirty Dingo mounts for my alternator and PS pump and I now have the clearance I need when using a small frame alternator.
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #3 of 18 (permalink) Old Apr 11th, 19, 05:06 PM
Kip
I used the Holley mid-mount accessory drive set up. Keeps everything nice and tucked in. Also used all of the Holley/hedman swap parts. It was a perfect fit... absolutely no fitment or geometry issues.
1967 SSRS
kv67ssrs is offline
post #4 of 18 (permalink) Old Apr 11th, 19, 05:14 PM Thread Starter
Bobby
Iím going with:
LS/LT COMPLETE ACCESSORY DRIVE KIT
Includes SD7 A/C Compressor, Alternator, P/S Pump, Tensioner, Belt, & Pulleys
PART# 20-138
But donít know which installation kit?
post #5 of 18 (permalink) Old Apr 11th, 19, 07:01 PM
Pretty sure itís 21-1 because they tuck the accessories as close as they can. The instructions for the 20-138 kit include measuring instructions to verify which spacer to use.
Sorry itís been a while and my memory is not that great anymore.
130fe and DT like this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 18 (permalink) Old Apr 11th, 19, 10:42 PM
Chris
130fe's Avatar
I had the high mount setup and switched to the mid mount. Better setup all around. I highly recommend the mid mount over the high mount setup. If you buy the Holley -38 kit, you still have to buy the PS reservoir and fitting for pump (to convert to AN6). The mid mount already includes that stuff, uses a C7 style water pump (cartridge style) and a 150 amp mechman style alternator.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #7 of 18 (permalink) Old Apr 12th, 19, 02:54 AM
DT
Donny
DT's Avatar
If I remember correctly, your water pump/balancer will determine what install kit to use ?? I think mine was the 21-1 on my GMPP LS3 (standard alignment). Better confirm this, I installed mine last year sometime.
DT is offline
post #8 of 18 (permalink) Old Apr 19th, 19, 07:25 AM Thread Starter
Bobby
Spent a half hour on hold #17 in line on the Holley Help Desk.
The guy said he could not be positive but thinks it is the 21-1 that I will need, so that is what I ordered and time will tell if it is the right one?
DT likes this.
post #9 of 18 (permalink) Old Apr 19th, 19, 07:41 AM
Vega$69's Avatar
The mid mount is a much better setup.
130fe likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 18 (permalink) Old Apr 20th, 19, 07:58 PM Thread Starter
Bobby
Sorry but donít understand? I would only think one would work? When I looked at the different images in the directions it seemed that I needed the 21-1?
post #11 of 18 (permalink) Old Apr 21st, 19, 04:35 AM
Beth
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #12 of 18 (permalink) Old Apr 21st, 19, 04:58 AM
Steven
stamatisg1977's Avatar
Match your balancer to the ones in this pic
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #13 of 18 (permalink) Old Apr 21st, 19, 05:01 AM
The Holley midmount is a completely different accessory drive that doesnít require adaptors. It also costs quite a bit more.
dhutton is offline
post #14 of 18 (permalink) Old Apr 21st, 19, 06:03 AM
Vega$69's Avatar
The Holley kit is $1350. Plus you have to buy the spacer kit for $60 and thePS reservoir for $100 so its $1410 total. The mid mount is $1800. $390 more and a much better system. It comes with its own WP so you can sell the pump off your crate motor to help offset the higher price.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 18 (permalink) Old Apr 21st, 19, 06:07 AM
Thatís a 28% premium. Just sayin.... Yes it is better imho. But the lower cost one while not quite as pretty is still a good option.
dhutton is offline
NEW - Holley LSx Mid Mount Serpentine Drive Systems! MCB Sponsors 1 Jan 10th, 19 01:16 PM
Water pump mods with Holley accessory drive NashvilleCat LSx Swap 11 Sep 10th, 18 08:56 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 09:37 AM
New Holley Mid Mount Accessory Drive Vega$69 LSx Swap 22 Mar 19th, 18 09:11 AM
Holley Acc Drive #20-137 question (LS3) DT LSx Swap 3 Nov 23rd, 17 03:57 PM
