A Backyard Mechanics Guide to an LS3 Swap - Page 11 - Team Camaro Tech
 23Likes
post #151 of 164 (permalink) Old Jun 21st, 19, 09:22 AM
Re: A Backyard Mechanics Guide to an LS3 Swap
Originally Posted by Sixty8Camaro View Post
Sorry but when you indicate GMPP pedal, I'm not sure that is what I have?
The following is what I purchased.
CORVETTE THROTTLE PEDAL ASSEMBLY
https://www.gmperformancemotor.com/P..._Code=19417903
Ok DSE bracket will work.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #152 of 164 (permalink) Old Jun 21st, 19, 01:57 PM
Chris
130fe's Avatar
I used the Monte Carlo pedal in my GMPP harness. Works great, not as bulky at the one in the kit and no re-pin necessary.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #153 of 164 (permalink) Old Jun 25th, 19, 04:02 PM Thread Starter
Bobby
So I have the stock oil pan removed and I'm a little unclear about some of the wording in the directions for the new Holley 302-2?
I think it is the wording in the 2nd paragraph "may be used"? What is the alternative to "may be used"? Is this suggesting that the full length windage try does not need to be used at all if you chose not to?
Is this indicating that the stock sheet metal plate in the following image has to be cut down to 14.25" and notched?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #154 of 164 (permalink) Old Jun 25th, 19, 04:17 PM
DT
Donny
DT's Avatar
You modify that windage tray as per Holley instructions. Yes cut down to 14.25 AND notched. Make sure all burrs are removed too.
dhutton likes this.
DT is online now
post #155 of 164 (permalink) Old Jun 25th, 19, 05:58 PM
Yep modify it or buy the F body windage tray they give you the part number for.
post #156 of 164 (permalink) Old Jun 25th, 19, 06:17 PM Thread Starter
Bobby
Thanks, their wording did not seem very clear.
Iíll try modifying the orginal and if I mess it up I see I can purchase the # they indicate on Amazon for $40.00
post #157 of 164 (permalink) Old Jul 9th, 19, 03:29 PM Thread Starter
Bobby
Was able to cut thru the windage tray as if it was butter with a cut-off disk. Should have taken some pictures but when your in the zone and focused you just "GITER DONE" without pausing to take pictures.
post #158 of 164 (permalink) Old Jul 9th, 19, 03:46 PM Thread Starter
Bobby
Next on the list was the Torque Converter and even though I watched many videos and knew that there would be two clanks to get the convert on the shaft I mistake the first clank for an actually clank. What I absoluly knew was NOT to draw the transmission in with the bolts.
Here I sorta though I was OK because the converter was resting below the outer surface of the transmission.
Here you can see as far as I was able to mate it up to the engine, and when I decided I needed to start over and backup a step and check for that Clank, Clank.
So during second attempt I kept shifting and jiggling the convert and definitely found that right 2nd Clank and the convert sat deeper into the transmission than during the first attempt.
Also bought some bolts and cut off the heads so that I could add some additional temporary alignment studs.
The second attempt was a success with the transmission mating up to the engine with no effort.
post #159 of 164 (permalink) Old Jul 9th, 19, 05:59 PM
Vega$69's Avatar
Only a complete success when you finish bolting the TC to the flex plate.
Good job even though I dont do automatics. They are for old guys and I'm only 68. Haha.
Love the 7 speed manual in my C7 ZO6
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #160 of 164 (permalink) Old Jul 9th, 19, 06:40 PM
Beth
I did the same with a cutoff disk. My LS was a truck LQ4 and Holley oil pan.
Nice work ! I broke a 700R4 pump when I didn't understand the two click method.
Back in the dark ages before Youtube videos.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #161 of 164 (permalink) Old Jul 10th, 19, 05:32 AM Thread Starter
Bobby
Wink Re: A Backyard Mechanics Guide to an LS3 Swap
Not sure for how much longer but at least your the correct year "68"
post #162 of 164 (permalink) Old Jul 10th, 19, 04:25 PM Thread Starter
Bobby
Took a look at the PDF for the harness but unable to 100% know how much of the cable\connectors need to be on which side of the firewall?
Perhaps the point of the connectors that indicate "Power Tap" and "Inputs\Outputs" need to be on the passenger side of the firewall?
So in the picture below I still need to move the Earl Seal to the left past the lose wires?
post #163 of 164 (permalink) Old Jul 11th, 19, 12:08 PM
Vince
vincevs's Avatar
I assume you did it already but the number they give you for the windage tray is shorter but still needs to be notched... just cut down the one you have.
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #164 of 164 (permalink) Old Today, 05:59 AM Thread Starter
Bobby
May I check with the experts?
The connectors that indicate "Power Tap" and "Inputs\Outputs", which side of the firewall will I want these for future use?
Engine Bay or Passenger side?
Headers - LS3 Swap Sixty8Camaro Exhaust and Headers 12 May 1st, 19 11:57 AM
Cost of LS3 Swap Sixty8Camaro LSx Swap 8 Apr 19th, 19 12:41 PM
LS3 ? or SBC bwarren LSx Swap 126 Sep 14th, 18 06:43 PM
67 Camaro RS LS3 & T56 Swap parts lists and advice needed red67RS New Member Introductions 0 Dec 11th, 17 02:13 PM
