Ls position in engine bay - Team Camaro Tech
 1Likes
  • 1 Post By stamatisg1977
post #1 of 15 (permalink) Old May 3rd, 19, 04:45 PM Thread Starter
Steven
stamatisg1977's Avatar
How close should the back of an ls engine be to the firewall in a 69 camaro?
Speedtech sent me their new lsx adapter plates that have 3 mounting positions
Stock
3/4” back
1-7/8” back
I know i have to go at least 3/4” back to clear the rack and pinion but if i go too far back i would have to reposition the center console to allow the shifter to come up through
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 15 (permalink) Old May 3rd, 19, 05:27 PM
Eric
Re: Ls position in engine bay
I have the Holley mounts, the gap from the back of the right cylinder head to the firewall is 1.5 inches in my 68.
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #3 of 15 (permalink) Old May 3rd, 19, 05:38 PM
Mine is about finger thick off the firewall....3/4"-1"
68 Camaro~LSx ~all motor
post #4 of 15 (permalink) Old May 3rd, 19, 05:40 PM
Vega$69's Avatar
I always move mine 3/4" forward of stock to allow a little more clearance for wiring etc. did so with my Speedtech sub and no R&P clearance issues at all.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 15 (permalink) Old May 3rd, 19, 06:04 PM Thread Starter
Steven
I cant go any further forward as my oilpan is a width of a piece of paper from hitting the rack
Tremec TKO 600
post #6 of 15 (permalink) Old May 3rd, 19, 06:22 PM
Vega$69's Avatar
Which OP are you using?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 15 (permalink) Old May 3rd, 19, 06:22 PM Thread Starter
Steven
Mast
Tremec TKO 600
post #8 of 15 (permalink) Old May 3rd, 19, 07:43 PM
Vega$69's Avatar
Right. I would use the Holley 302-3
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 15 (permalink) Old May 5th, 19, 02:32 PM
DT
Donny
DT's Avatar
Keep in mind the location of your shifter handle when deciding what position to use for the engine. Just a thought.
DT is offline
post #10 of 15 (permalink) Old May 5th, 19, 07:36 PM Thread Starter
Steven
I heard the holley doesnt fir good with the speedtech frame
Tremec TKO 600
post #11 of 15 (permalink) Old May 6th, 19, 02:13 AM
Vega$69's Avatar
You're right. I used Autokraft pan with my Speedtech frame.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 15 (permalink) Old May 6th, 19, 09:03 AM Thread Starter
Steven
since im a tall guy im moving the seats back too.
the plates can move engine back .9" to 1.75"
i dont mind welding up the hole i cut for the shifter and making a new one an inch or two further back
DT likes this.
Tremec TKO 600
post #13 of 15 (permalink) Old May 16th, 19, 03:24 PM Thread Starter
Steven
John, what frame stands did you use on the speedtech frame?
They sent me stands that have the drivers side raller pushing engine over 3/4” but now my trans crossmember does not fit
Tremec TKO 600
post #14 of 15 (permalink) Old May 16th, 19, 04:12 PM
Vega$69's Avatar
I used the Speedtech supplied LS stands.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 15 (permalink) Old May 16th, 19, 04:21 PM Thread Starter
Steven
Were they the same height
Tremec TKO 600
1967 RS/SS Convertible engine bay color SS1967RS Restoration Corner 1 Jul 25th, 18 12:28 AM
67 L35 396 engine bay Brent396 Restoration Corner 2 Jul 3rd, 18 06:18 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 09:37 AM
back-fire ... engine under compression Larry Madsen Engine 12 Apr 3rd, 18 01:13 PM
Value of Used 350 Engine MYRSSS What's it worth? 10 Feb 14th, 18 05:06 PM
