Flexible Transmission Cooler Lines - Team Camaro Tech
 1Likes
post #1 of 20 (permalink) Old Jun 19th, 19, 09:32 AM Thread Starter
Bobby
Having trouble finding "Flexible Transmission Cooler Lines" to use for my 4L65E transmission?
I thought I found some at Summit "Advance Adapters Flexible Transmission Cooler Lines 23-1500-60" but when I called "Advance Adapters" they told me they don't make any lines for the 4L60's series.
Is my only option to make my own?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 20 (permalink) Old Jun 19th, 19, 12:34 PM
DT
Donny
DT's Avatar
Re: Flexible Transmission Cooler Lines
Check EBay, I saw a bunch of kits the last time I looked. Just confirm the fitting sizes. Just a thought.
DT is offline
post #3 of 20 (permalink) Old Jun 19th, 19, 03:08 PM
If you can find the correct size AN fitting for your transmission and oil cooler, you can make your own with the proper braided line
HawkX66 likes this.
68 Camaro~LSx ~all motor
post #4 of 20 (permalink) Old Jun 19th, 19, 03:23 PM
Pretty sure the fittings on the transmission are 9/16 o-ring. Took me a while to figure that out on my 4L65E.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 20 (permalink) Old Jun 19th, 19, 05:40 PM Thread Starter
Bobby
I might look into this place since I need fittings for the entire swap?
https://www.anhosefittings.com
Anyone use them before?
post #6 of 20 (permalink) Old Jun 20th, 19, 05:07 AM
DT
Donny
DT's Avatar
I have not heard of these guys. I used the Orme brothers when I needed hose/fittings etc. I had them make up the hose for me. They are TOP NOTCH. https://ormebrothers.com/
DT is offline
post #7 of 20 (permalink) Old Jun 20th, 19, 07:40 AM Thread Starter
Bobby
Hi Don,
May I confirm this is what you are describing that I will need to use something like these at the connection points on the 4L65E?
https://www.jegs.com/i/Earls/361/AT985046ERL/10002/-1
post #8 of 20 (permalink) Old Jun 20th, 19, 09:07 AM
Greg
One word of caution on the Ebay kits. I ordered a kit that was supposed to be good for transmission lines. It said so right in the listing. Once I got the hose I looked it up online and the hose they sent was not rated for transmission fluid. They did refund my money however.
I used braided line and there were adapter fittings that screwed into the transmission. These are the fittings I used on my 4L70E.
https://www.jegs.com/i/JEGS/555/113601/10002/-1
This is the hose:
https://www.jegs.com/i/JEGS/555/100913/10002/-1
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #9 of 20 (permalink) Old Jun 20th, 19, 11:50 AM
Hi Don,
It looks like that but they donít spec the thread pitch etc. I will look later to see if I can find it.
post #10 of 20 (permalink) Old Jun 20th, 19, 02:03 PM
This should be it:
https://www.ebay.com/itm/FRAGOLA-495...k/163373594653
post #11 of 20 (permalink) Old Jun 20th, 19, 02:48 PM Thread Starter
Bobby
So just took a quick look at my transmission.
Do I remove these fittings to use the ones Don is recommending or is there a fitting that works with these stock ones?
post #12 of 20 (permalink) Old Jun 20th, 19, 02:52 PM
I was never able to find a compatible adaptor so I removed those. That doesnít mean they donít exist, it just means I couldnít find them.
post #13 of 20 (permalink) Old Jun 20th, 19, 07:11 PM
Lonnie
Lonnie P's Avatar
Remove those fittings & buy a set of -6 fittings for the 4L60/65E trans.
They should be 1/4" NPT straight thread.
Then buy some stainless braided teflon lines & fittings & build your own.
I ran braided lines full length instead of any hard lines.
You can also get a lot of aux trans coolers with -6 AN fittings on them, making the install very easy.
https://www.summitracing.com/oh/part...1114/overview/
My hoses ended up with 90's on the trans end & straight fittings on the cooler.
Lonnie P is offline
post #14 of 20 (permalink) Old Jun 21st, 19, 05:47 AM
Greg
I linked you the proper fittings from Jegs up above.
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #15 of 20 (permalink) Old Jun 21st, 19, 06:12 AM
Lots of opinions and guidance here. It seems I am in the minority so go with the majority.
